Dome light switch not working. Lights work
Pop the light cover off.
Remove the two gold screws on each side of the fixture.
There are two small clips at the front of the light to pop off, then the light fixture comes down.
Remove the electrical connector
Take the fixture inside and remove the two gold screws holding the white thing down.
This is what mine looked like. It kinda worked when it wanted to.
Remove the slide switch but BE CAREFUL, it's easy to lose the little ball bearing detent balls.
I cleaned mine up with a brass brush in my Dremel at the lowest speed.
Works great now.
Works great now.
MP2k - Thanks a bunch. Your pictures made repair of the map light simple. Problem was exactly as you described except my contacts were more corroded with lovely green deposits. Just two comments:
-Flat head screw driver to remove lens was more medium in size (as in your picture).
-After cleaning with my Dremel, I applied a swipe of WD-40 with a Q-Tip to the contacts as a preventative measure.
RESULTS: Everything worked perfectly after cleanup - thanks again for taking the time to post the fantastic pictures.
look under the steering column towards the door side, you will see the fuse panel. i just checked mine today and it was a 7.5 amp fuse. the fuse panel label is on the quarter panel.
Fixed with Q-tips and vinegar! Contacts were light green and dull, now shiny again! Working perfect!
