Done
Old Oct 8, 2002 | 07:40 PM
  #21
TSS2000's Avatar
Hey cjb80 what you think about octan boost by nos ,
the one you add to your fuel. does it give you higher
octan gas?
Old Oct 8, 2002 | 08:13 PM
  #22
Sunder's Avatar
CJB,
You mentioned you had new pistons. Are they just forged, or do they drop the compression as well?
Is 19 degrees significantly retarded from a naturally aspirated version? I'm not sure what stock is...
Thanks.
Old Oct 9, 2002 | 03:15 AM
  #23
Whitelightning's Avatar
I think the pistons he has drop the compression.
Old Oct 9, 2002 | 04:07 AM
  #24
My R2's Avatar
damn is all I can say....
Those are some impressive numbers (I know you are guesstimating but still). I bet the car is scary as ____ now...
so you are pretty much done with the motor? no more power, huh? I'll give you a year then you'll be craving for more...
So yellow S2000s MUST be the fastest, huh?
Old Oct 9, 2002 | 05:13 AM
  #25
marcucci's Avatar
Echo...
Originally posted by Tedster
Chris,
I didn't see a bored throttle body in your list of parts; are you doing this with the stock TB?
Thanks,
Ted
Old Oct 9, 2002 | 05:24 AM
  #26
cjb80's Avatar
Holy cow, I can't believe how many people are interested in if I have a bored throttle body. Yeah, I had mine bored out a long time ago, but I seriously doubt it affects performance at all. When air is pressurized it will push it through anyways. I had it ported by Pro Flow.
The pistons are forged 9:1 pistons. I believe stock ignition is around 40 degrees at 9000 rpm, 19 degrees is pretty conservative but keep in mind it's also tons of boost.
I don't know if he'd appreciate me saying this, but based on Mike's experience advancing timing just a few degrees at high boost levels yields HUGE gains in power. Perhaps 30-40 hp. But then you get closer and closer to the edge of detonation. (Where peak power is made)
If I were to run it up to 25psi or more, I would probably back ignition down to 15 degrees or so.
Chris
Old Oct 9, 2002 | 05:37 AM
  #27
BlackS2000Turbo's Avatar
Chris,
At this point better safe than sorry. You have nothing to prove. Nice job with everything. You have the patience of a saint. I don't on the othe hand which is why I'm so glad you've done all of this to pave the way for me...
Larry
Old Oct 9, 2002 | 06:04 AM
  #28
HwangTKD's Avatar
CONGRATS,
Please, please take this monster to the track and do some off idle launchesand post the time slips!
Bobby
Old Oct 9, 2002 | 09:27 AM
  #29
cbender's Avatar
Hi Chris,
You've been on point for the rest of us for months now. Glad you made it to the end of the tour. Enjoy your beast.
And congratulations: on power-to-weight ratio (roughly 400 engine HP per ton at 19-20 psi of boost, according to your seat-of-the-pants dyno), you've pretty much surpassed everything out there, including a Ruf R Turbo (345Bhp/ton) and a Lambo Diablo (392Bhp/ton), and you're closing in on a Ferrari F50 (424Bhp/ton).
I can't even imagine how it must pull...
Old Oct 9, 2002 | 09:39 AM
  #30
Tedster's Avatar
[QUOTE]Originally posted by cjb80
