downshifted by mistake
Old Jun 24, 2006 | 12:18 PM
march2000's Avatar
Default downshifted by mistake
I had a track day about 3 days ago and made a mistake on an up shift. I was suppose to go to 3rd (near redline on 2nd), but the car was under load so it was hard to get into gear and I manage to put it in 1st and lock-up the rear wheel and went landscaping. I lock up the brake and push the clutch in as fast as I could but everything seems very fast (mis-shift then wham) I didn
Old Jun 24, 2006 | 12:55 PM
RACER's Avatar
Originally Posted by march2000,Jun 24 2006, 01:18 PM
near redline on 2nd, I managed to put it in 1st and lock-up the rear wheel and went landscaping.
Old Jun 24, 2006 | 01:11 PM
Iceman1's Avatar
[QUOTE=march2000,Jun 24 2006, 03:18 PM] I had a track day about 3 days ago and made a mistake on an up shift. I was suppose to go to 3rd (near redline on 2nd), but the car was under load so it was hard to get into gear and I manage to put it in 1st and lock-up the rear wheel and went landscaping. I lock up the brake and push the clutch in as fast as I could but everything seems very fast (mis-shift then wham) I didn
Old Jun 24, 2006 | 01:15 PM
Kobe's Avatar
it was hard because you were trying to shift into the wrong gear..
Old Jun 24, 2006 | 01:39 PM
gfacter's Avatar
Well you didnt trigger any CEL's so it's unilkely you bent a valve. Exactly what speed did you shift at?
Old Jun 24, 2006 | 03:16 PM
afwfjustin's Avatar
If you were at redline when you went into 1st there is a chance you could have damaged something. However, a lot of people have overreved (myself included once) and never had a problem. I never got mine checked and mine runs great, however I don't "advise" this necessarily. For peace of mind, get it checked. I'm getting tires put on next week and will have my mechanic check out my head because I want to setup nitrous soon and I'm scared about the overrev I had close to a year ago.
Old Jun 24, 2006 | 05:56 PM
silencertk's Avatar
There's tons of threads about overrevs and all will basicly tell you the same thing. your engine can be without symphtomes for months, but with a cracked retainer it could drop a valve any time.
The only way you'll know for sure is to have it checked. At least take the valve cover off and do a visual inspection.
Old Jun 24, 2006 | 07:36 PM
Ek9's Avatar
Ek9
Banned
I missed a shift from 3-2 instead of 3-4. It was obvious when I next cranked the engine that I'd bent valves. I limped it home 5 hours from the track (which is why I have a trailer now) . I DIDN'T have any CEL's and DID have bent valves so, a CEL isn't a great symptom. They were just slightly bent. I ran the rest of the session with the damaged valves and couldn't even tell. It's when I asked it to idle that the problem became apparent.
Honda engines are tough. I imagine if had been any other engine I would have blown it.
I question whether you actually over-revved it. I wouldn't be surprised if locking the wheels up and sliding protected the engine from an over-rev. In my case the tach pegged so, it was obvious.
Old Jun 24, 2006 | 09:03 PM
oakfloor's Avatar
IIRC this engine will turn up to 10,700 revs before you bend a valve. you should have it looked at to be sure. billman 250 has some pics posted up showing what to look for.
Old Jun 24, 2006 | 09:09 PM
march2000's Avatar
That what I thought that it might take months before the symptom shows up but I'm sure that those were more of a street driven car. I drove the car another 70 hard miles on the track after that happen and the valve hasn't drop yet and I would have thought for sitting at redline for 70+ miles will speed up the process so that is why I thought my engine is okay.
