downshifted by mistake
Originally Posted by march2000,Jun 25 2006, 07:17 PM
I was going to replace my valve cover gasket since I don't want the oil to leak through after I put it back together. But I think I will just re-use the old gasket since Honda dealers don't replace them either when they do the valve adjustment.
I wil inspect them hopefully next week and we'll report back.
You probably won't find a problem, so far I haven't, but given the potential for major engine damage it just makes sense to take the time to take a look.
My dealer quoted me 6 hours labor and the cost of the new AP2 retainers to replace them. I'm not sure you would see any visual indicators necessarily if a retainer was damaged--for instance the damage and weakness could be on the underside against the spring seat, which would not be visiable.
Given the comparative costs, I would think replacing the retainers in the event of a massive overrev would be cheap insurrance.
Originally Posted by fallcityfisher,Jun 25 2006, 12:06 PM
Your probably fine. If everybody who overreved thier engines took it back to the dealer or some other shop to check the engine there would'nt be an s2k on the road and honda could never sell them. These engines are very tough: I should know I've worked on them for 30 years. But if it will make you feel better I,m sure someone will be glad to take your money and tell you the same thing.
Sorry, but there have been NUMEROUS members who have done exactly this, and gone about their way with the same lacadaisical attitude. Then 4 months later, WHAM, piston to valve contact from the retainer they cracked 4 months previously from their overrev in which the car seemed fine. And there are others who have done this and had nothing bad every happen.
Bottom line, you overreved no matter how you look at it. You have 2 choices.
A. spend $150 to get the retainers checked (or do it yourself if you know what to look for) You could even get a valve job while they're under there for a few bucks more, and save some cash.
B. risk that you may or may not have to spend thousands of dollars later on because you wanted to save $150 after a mechanical overrev.
I'll take option A. thank you. Be safe about it. don't just assume it's fine. Especially going into 1st gear at 60mph. That's a pretty decent overrev, no matter how much you did or didn't spin out.
Originally Posted by evf2000,Jun 25 2006, 12:14 PM
I would take a look at the retainers just in case.... I did about the same thing ...yeah it lasted about 3 months but then I droped a valve and I wasn't even pushing it hard. $9750.00 and 10 months later I had a new engine. Might want to check it out if I were you.
so again.
A. gauranteed $150
B. gambled almost $10,000
hmmmm.
Billman can correct me if I'm wrong, but I think it would be foolish to replace the retainers if there is no visible sign of stretching. Billman has pictures to show you what to look for (try the search function).
Basically all you have to do is pull the cover and look at the height of the valve stems and retainers relative to the keepers.
Originally Posted by floridawriter,Jun 26 2006, 02:58 PM
Sorry,
Who is Billman?
Who is Billman?
Thanks guys, I just got done pulling the cover and putting everything back together. The retainers look good with no visible stretch or crack. I put the valve cover back on and I made sure it went in okay, but didn't know the exact torque spec for that so I just tighten it down with wrench (not too tight), I just found out that it doesn't take much (like 8-9 ft.lb) so I hope everythihg is okay; most likely overtighten them by a bit!
Now are there any ways to inpect any leak from the valve cover gasket? I just wasn't sure if the overtighten the bolts will cause any leak or not. It does look like it is zipping through a couple of places (like on the front left side [corner] of the engine [left from the front of the car, and right side if you are heading toward the front of the car) but it might just be when I put the cover back on as it didn't go back in perfectly at first so with me moving the cover around it might pick up oil on some places.
