Dreadful hood rattle - not the common culprits
I'm done with this hood rattle. I'm about to go bananas. My AP1 never had this problem. My AP2 has done it since I've bought it almost 2 years ago.
I have tried multiple multiple times to adjust the hood latch and the bump stops in various configurations to get it to quiet down - to NO success.
I've read through the found a rattle thread but I can't find anything that is similar to my problem. If I press my hand on the hood I don't think it changes the rattle much so maybe it is coming from under the hood somewhere, in the engine bay? I should probably try starting the car this evening on my way home from work with the hood up to see if I still hear it and will update y'all.
Other notes:
- The rattle is not present when the car is moving or at least I can't hear it
- It's worst when I start up the car cold, it hums a lot louder as it's warming up and then it will quiet down after running for about 1-2 minutes of idling
- Even when it's warm, it will still come back at idle for several seconds (at stoplights)
- Doesn't matter if A/C is on or off, or heat is on or off
- I recently (6 months ago or so) installed an FIPK, but it did it before then anyways, with the stock air box
- I've looked around thoroughly for anything that could be partially wedged somewhere in the engine bay but can't find anything
- I've checked the belt tensioner and I don't see any movement when idling and the markings on the tensioner show that it should be fine
Any thoughts?
Other notes:
Any thoughts?
Sheet metal heat shields around header secure?
http://image.hondatuningmagazine.com...eat_shield.jpg
Are you sure you isolated the noise to that area? I had a crazy rattle and came to find out it was my secondary O2 sensor had come loose from my TP (or cat if you are unmodified).
I also even wedged a few shop towels between the heat shield and the battery side of the heat shield to "dampen" it if it was still the shield that was vibrating but that wasn't it either.
i found a rattle with the hood support rod...and the related plastic parts. one for the hood support and one for the "tie down" that it fits into. i have this rattle whenever the idle gets lower or i let out the clutch without enough gas...its an engine vibration related issue. I got new parts, these two plastic things and it rattles less. so you can remove the support to see it that is the rattle you have.
On my way out of work yesterday I popped the hood to see if that's where the noise was coming from (and the support rod) but the noise was still there. Albeit it was a little quieter however the car was also partially warm (I had driven it at lunch time) and it got to 3 bars (AP2 though) just idling in about 60 seconds. If the car was bone cold it would take a solid 5-10 minutes or more to get up to true operating temp.
I was going to try it again this morning on my way to work but it was raining so I took the truck
One thing I noticed is that as is was making the noise i pressed my hand on the exhaust header shield (not the vertical heat shield), the one that covers the exhaust header and I swear the noise dropped off right as I put my hand on it, but that was probably around the time the noise was going to go away anyways.
By the way. The noise isn't so much a rattle as it is a vibrating drone. It's more plastic-sounding than metallic.
