Driver side window goes down in "stages"
Old Mar 18, 2010 | 08:59 AM
DJT's Avatar
DJT
Default Driver side window goes down in "stages"
So when I switch the top-down button to put the top down, the passenger side window goes all the way down. The driver's side window, however, only goes down a bit. If I press top-down again, it goes down another few inches. So on and so forth. After about 3 or 4 pressings, it will then go all the way down.
This strikes me as pretty odd. Curious if folks have seen this before and if any easy DIY solutions are available.
Thanks,
D
Old Mar 18, 2010 | 09:37 AM
ryanfeldman's Avatar
mine does this too. you can try to reset the "auto down" button by pressing the button down for 5 sec while the window is all the way down, press and hold the button up when the window is up. do this a couple of times tends to reset it and it should work.
now mine will be reset for 1-2 times and then go back to the problem described above.
Old Mar 18, 2010 | 09:50 AM
whiteflash's Avatar
sounds like a motor issue?
Old Mar 18, 2010 | 10:39 AM
2slow2Bfurious's Avatar
from the under the hood DIY section. apparently there is a fix for that.
https://www.s2ki.com/forums/index.php?showtopic=131795
i have the same issue, but i can't follow instructions otherwise i would've tried this already.
Old Mar 18, 2010 | 10:44 AM
DJT's Avatar
DJT
Ah, I didn't equate that with the convertible top but as someone else suggested, it might be what I need. Having read that other post, I see:
"most of use the little tube thingy to put inside the back rear window to prevent the window from wrinkling, and in the process of putting it down we stop the top halfway."
What's the "little tube thingy" he's talking about. I normally just hop out of the car and manually push the plastic window into a curved position to promote proper folding. It "kinda" works. Is there a "tube thingy" I don't know about?
Old Mar 18, 2010 | 11:34 AM
I don't know what the tube thingy is since I don't have a plastic window, but I guess my problem started because i often open the top half way when i'm cleaning it and to dress all the rubber seals with rubber protectant.
Old Mar 18, 2010 | 12:07 PM
tuby thingy = swimming noodle
Old Mar 18, 2010 | 02:48 PM
madcowdk's Avatar
Awesome!! I thought i was the only one with this problem.
Doing this when I get home.
Old Mar 18, 2010 | 02:54 PM
DJT's Avatar
DJT
Wow, I just did it. It works! To be honest "the fix" is pretty damn hysterical. Either that or sheer (fault tolerant) engineering genius.
Old Mar 19, 2010 | 11:47 AM
DJT's Avatar
DJT
Meh. The fix doesn't hold. Seems as long as you need to do the separate:
1. open top 1/2 way
2. insert neck pillow into plastic window
3. fold down top the rest of the way
method, the window keeps setting itself back to "staged" rolldown. ;-(
andy s2k
Oct 27, 2009 08:27 AM
Petrol-Head
Sep 24, 2009 01:42 AM
heathas2k
May 21, 2008 01:31 PM
Teh Legacy
Apr 13, 2008 05:41 PM
crav3s2k
Jan 26, 2008 11:37 PM
