Driver window wont roll down
Old Oct 13, 2004 | 07:36 AM
VTECturbo04's Avatar
Default Driver window wont roll down
Everytime I go to put my top down the driver side window goes down about 2 inches and stops. If anyone out there can help me figure out what its catching on Id greatly appreciate it.
Old Oct 13, 2004 | 08:13 AM
Paulieblks2k's Avatar
That is a TSB for your 2001. I had the same problem with mine and took it in to the dealer and they replaced the motor. Give it a try.
Paulie
Old Oct 13, 2004 | 08:42 AM
elude's Avatar
i had the same problem and did the temporary window fix.. it worked fine until i did the roof thing.. after a while i changed my factory speakers and had to remove the door panels which included unclipping the window harness..
after i unclipped the harness i blew out the dust and did a firm connect back together.. ever since, my window has been fine.. give it a shot, its free and fast.. just my .02cents tho.
Old Oct 13, 2004 | 11:17 AM
Thanks both of you for the help. I'll try taking the panel off and cleaning that out and making sure the connection is good. If that doesnt work, then I guess I'll be forced to take it to the dealership. Once again, thanks.
Old Oct 13, 2004 | 11:55 AM
Ludedude's Avatar
Administrator
Just FYI: https://www.s2ki.com/home/index.php?option=...id=34&Itemid=41
RalstonS2k
Sep 5, 2012 10:02 AM
nwaaa11
Nov 24, 2010 02:27 AM
1320performancefreak
Apr 29, 2008 09:47 PM
tetsuo73
May 10, 2005 12:38 PM
EMarkDDS
Feb 27, 2003 08:24 AM
