ECU replacement
Old Apr 17, 2015 | 09:34 AM
JR0130's Avatar
Default ECU replacement
I have a Honda S2000 year 2000, manufactures Part# 37820-PCX-A02. What precautions do I have to take when replacing an OEM ECU? Is this procedure must be taken to a Honda dealer or mechanic with sophisticated OBDIi or is this a matter of plug and play! I see some ebay ad that includes ignition with immobilizer and key, is this necessary to replace when replacing with same yr and same part#? Appreciate input please!!!
Old Apr 17, 2015 | 11:44 AM
cdelena's Avatar
You will get slightly better performance with an '02 - '03 and as I understand it you will have to get a dealer to normalize your immobilizer.
I use a Mugen ECU in my '00 and swap back to OEM to pass smog every two years and just do without immobilizer but you don't have that option with OEM.
Old Apr 17, 2015 | 12:11 PM
Slowcrash_101's Avatar
Yep as stated, aside from the immobilizer thing, where you have to take your key to the dealer, or somewhere that provides that service, then you just hook up all the connectors in the wiring harness to the ECU.
Old Apr 17, 2015 | 03:07 PM
JR0130's Avatar
Old Apr 17, 2015 | 03:14 PM
JR0130's Avatar
Thanks for input, sounds like no choice but to take the car to a mechanic to have install it properly, once I find a OEM replacement. Any idea used OEM price? I like your input "cedelena" although I have 00" S2k may be I can look for 02" or 03" (OEM brand new calls for same part number for 00-03")
Old Apr 17, 2015 | 07:38 PM
They go for about $100 usd used.
Old Apr 18, 2015 | 09:19 PM
MM3Kwolik's Avatar
What is your purpose/reasoning for replacing the ECU OP?
DutchyFutch
Oct 11, 2014 11:40 AM
f20kills
Aug 30, 2012 03:37 PM
gios2k
Jan 29, 2012 09:56 AM
GoKartFun
Feb 24, 2006 02:16 PM
jimbo69ny
Jul 10, 2003 08:53 PM
