Effects +/- removing/eliminating cat?
Old Feb 15, 2008 | 06:48 PM
vtec4life's Avatar
I was researching for an exhuast for my s2k but decided not to as there won't be much gains and that I don't want to ruin the comfort of driving so I searched and alot of people remove the can instead of the resonator and then use a test pipe and they said they had a few gains and liked the growl tone that it gave too. I'm considering this mod as well
Old Feb 15, 2008 | 07:09 PM
qbmurderer13's Avatar
Do not remove your resonator, it will not give you a growl, it will give you a tin can raspy noise as in here http://www.youtube.com/watch?v=aiQWitHJj-U a test pipe will sound about the same as stock. A single 70mm exhaust combined with a test pipe could get you gains up to 15 or more whp. But its almost impossible to tell the difference of a stock exhaust with the cat and a stock exhaust with a test pipe.
Old Feb 15, 2008 | 08:06 PM
Berlina_Black's Avatar
Originally Posted by qbmurderer13,Feb 15 2008, 07:15 PM
I HIGHLY recommend getting the test pipe, I got the berk one that came with the check engine light fix. Car sounds almost the same, just a tiny bit louder. Weighs less than half of the weight of the cat, and I also gained 8whp and 5tq with the stock exhaust. Dyno proven back to back. Cheapest way to get that much horsepower. Theres no emissions testing in florida so thats not a problem.
I can't wait till mine gets here (Tuesday) ordered a berk tp /w cel fix, i was expecting to get like 4 hp and 3 tq but ill take 8 and 5.
Old Feb 15, 2008 | 08:50 PM
Soul Coughing's Avatar
+ to no cat
I found the car made a bit more power, it lowers the drone of aftermarket exhaust and in my car made the stock exhaust sound a little meatier!
- to cat
Smells like crap
cops can be dicks
your hurting the ozone with horrible CO, NOx and unburnt hydrocarbon emissions
AND IT STINKS!
Old Feb 15, 2008 | 08:52 PM
I actually love the smell, just smells like gasoline thats all.
Old Feb 15, 2008 | 09:58 PM
If it just smells like gasoline, i kind of like the smell, why would everyone complain that it stinks real bad?
Old Sep 16, 2008 | 08:25 AM
BlackisFastest's Avatar
Cause they're pussies...
Old Sep 16, 2008 | 08:42 AM
slipstream444's Avatar
Because you're polluting.
Unlike other mods that will only void the warranty for the part replaced, removing the cat voids the entire factory warranty - and it violates Federal law.
Federal law is pretty strict regarding the removal of the cat in that it can only be replaced if the original cat doesn't work. This can of course be bypassed if you replace the cat with a comparable replacement cat (the old sledge hammer to your original cat, replace it with an aftermarket cat, and a story to go along with it) - but not with a test pipe.
Most folks will tell you that no one will ever inspect your car, but it only takes your local pokey needing to up their ticket intake to smell the absence of your cat to pull you over - and then you can loose your car due to the strictness of Federal and most local/State laws. While Florida does not currently require inspections, it is still illegal to tamper/remove your factory cat. The fines are not cheap either.
Additionally - there are tree-huggers out there that will turn in your information to the local authorities due to the smell associated with removing your cat (I've read a few articles regarding this). That gives the local authorities probable cause to inspect your car.
5-10 HP is not worth all that hate and discontent. The Berk aftermarket cat flows 80% as well as the test pipe and weighs less than the stock cat. You can get away with an aftermarket cat - but not a test pipe.
Old Sep 16, 2008 | 10:38 AM
chuhsi's Avatar
The test pipe smell was particularly strong in my car. I thought I would get cancer from all the nasty fumes. Cars would even pull up to me to tell me that my car was broken because it smelled so bad.
I went with the hi-flow cat and all's good.
Old Sep 16, 2008 | 10:56 AM
Nippon's Avatar
Tell em' slipstream
Forziii
Jan 8, 2016 01:58 PM
jst2878
26
May 27, 2015 12:25 PM
hondabruh
Aug 14, 2014 07:48 AM
ZKilla55
Sep 30, 2009 02:47 PM
S2Kart
Nov 13, 2007 05:14 AM
