elusive electrical problem
Old Nov 4, 2010 | 05:20 PM
SgtB's Avatar
Originally Posted by mister x,Nov 4 2010, 05:04 PM
The green color is copper corroding, I can't think of any load situation where that would cause this. More likely water or electrolyte somehow getting inside the insulation.
More than likely it is simple corrosion, but heating the connector will cause it to corrode very quickly as well. Excessive heat burns the coating off.
Old Nov 5, 2010 | 06:09 AM
idea-catalyst's Avatar
[QUOTE=91crxSi,Nov 2 2010, 06:35 AM] yes, i have a new battery and alternator. the battery is fine. it has never been hot, no swelling, etc.
I will try the dielectric grease idea. thanks for that one...
about voltage fluctuating, i tested two cars (another s2k and an altima), while idling, and there was no fluctuation at all. I tried turning on headlights, and the radio, and they showed no fluctuation, while my car would drop voltage when I turned on the radio and headlights, but never getting as low as the two control cars.
I was
Old Nov 5, 2010 | 01:35 PM
91crxSi's Avatar
ok. so the original alternator was definitely overcharging, with busted diodes. the first battery ended up bloating, and smoking, and did not explode, fortunately. So, i assume that the power wire to the alternator was overheated due to this, and the coating is now gone, which lead to the corrosion.
what should I coat the wire with?
i will definitely clean my grounds and add additional ones. i do not have a sound system. the car is MY01, so im sure it needs cleaning, and additional grounds should be nothing but beneficial.
THANKS ALOT GUYS!
lude92_si
Dec 15, 2017 07:16 AM
BS2K00
Feb 2, 2016 07:33 AM
jesse_ryan
Aug 11, 2014 06:35 AM
J-GO
Jun 21, 2011 07:16 PM
s4play
Feb 19, 2009 09:14 AM
