Engine Check Light..
Old Dec 10, 2008 | 05:55 AM
The Gent's Avatar
Try resetting the ecu... I was getting a check engine light when I changed my filter and it fixed the issue.
Old Dec 10, 2008 | 06:29 AM
da_wesmeista's Avatar
Make sure the vacuum lines are connected properly. I kept on getting check engine lights with my fujita until I figured out that two of them were switched.
Old Dec 10, 2008 | 06:33 AM
funkemonke's Avatar
yeah, there is a big chance that the vacuum lines are connected wrong.
its a little confusing but you'll get it.
like what the gent said, reset ecu. but i would 1st fix the issue and double check triple check that the lines are connected properly, then reset ecu.
gl
Old Dec 11, 2008 | 09:15 AM
mrxwormxsayz's Avatar
I found the hoses.
The real small hoses connected to a plug looking thing thats attached to the side of the intake right?
I switched them but what if they are switched is it bad for the car?
And I'm not sure which goes which can I get a very detailed description?
Old Dec 11, 2008 | 06:53 PM
Kirpich's Avatar
A repair manual will have all the diagrams. It'll pay for itself many times over if you read it and follow it. Probably in a year, on maintenance alone.
DannyInKorea
Feb 16, 2006 09:32 AM
gt2690b
Jul 5, 2005 10:59 PM
acuradrian
Sep 19, 2004 02:27 PM
s2khondaimport
Aug 18, 2004 07:46 PM
turbomadness
Feb 18, 2002 11:05 AM
