engine fire -> damaged harness
Old Jan 30, 2007 | 01:50 AM
addisonc's Avatar
Default engine fire -> damaged harness
Last weekend, I had an oil leak while driving on the highway. This resulted in an engine fire that caused damaged to the harness that connects the VTEC solenoid to the engine:
My first question is. If I were to order the parts to replace it, does it have to be the whole ENGINE WIRE HARNESS (illustration 1 on the pic below)?
As you can tell from the first picture, the wire still exist, but it's missing all the insulation. Is there other alternatives besides purchasing a complete harness? I'm not so handy with a soldering iron. But, is there any way I can tape this up to heatproof this?
Any input would be greatly appreciated. THANK YOU!
Old Jan 30, 2007 | 04:00 AM
Slows2k's Avatar
You'll need the complete engine harness, or find someone who can repair it. The hard part to find will be the connectors that are probably damaged, they are not sold seperately.
Old Jan 30, 2007 | 05:19 AM
CoralDoc's Avatar
Unfortunately, Slows2k is correct. Either pony up for a complete harness or have yours repaired. Considering the price for a new one, I'd at least attempt a repair before laying out the $$.
Old Jan 30, 2007 | 05:32 AM
freq's Avatar
Soldering iron, wire of the correct gauge, solder, wire loom, good electrical tape.
Old Jan 30, 2007 | 05:48 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If you were a paid member, I'd sell you the part of the harness you need.
Old Jan 30, 2007 | 06:07 PM
Stratocaster's Avatar
If you want to buy a complete harness, let me know. I have a few.
Old Jan 31, 2007 | 10:27 AM
addisonc's Avatar
That's more than enough incentive to join. done. I'll join today and PM you about the harness. thanks Bill
Guys, I have another issue. the engine oil leak inside the header (inside the heatshield). I took it to a detail shop to clean the engine including the heatshield. Yet, it is still fuming!
I checked the dipstick, no oil leak. Temperature gauge is normal. No check-engine light. The gas consumption is normal. The fume is definitely coming from the manifolds. Should I be worried? What do you think about me letting the car run idle for an hour?
Old Jan 31, 2007 | 12:55 PM
Spec_Ops2087's Avatar
It'll fume for a while I think...
When I got a new exhaust it came with a thin layer of oil in it...Took a few hundred miles to burn it all off.
Old Jan 31, 2007 | 04:45 PM
Slows2k's Avatar
It's most likely residual oil burning off.. I'd assume the oil filter leaked and oil went everywhere & caught fire. It's not gonna be an easy clean up getting all the oil cleaned off.
Old Jan 31, 2007 | 05:10 PM
addisonc's Avatar
Wow, you have psychic abilities.
