Engine Light >> Knock Sensor
Old Jul 19, 2004 | 01:45 AM
2_and's Avatar
Default Engine Light >> Knock Sensor
HI guys,
i have been having this problem for few days.....its starts when the engine light suddenly turn on by itself, i didnt do anything to the car...so i went to honda dealer, and they told me that the knock sensor is broken (looks like its been damaged)....the knock sensor isnt mount properly, its sort of hanging around....recently like 150 miles ago, i changed my clutch...could it be the cause??could it be the clutch guy damaged it while installing the clutch>???
does any1 here had same problem with me??and where is the knock sensor??dealer told me its near header, but i couldnt find it.....can some1 help me....
thx alot....
and yeah the weird part is, the light will off when u turn off the car and put it back on....but when travell approx 200m, it will start to on again...
Old Jul 19, 2004 | 06:17 AM
xviper's Avatar
I don't have my Helm manual handy, but I recall that the knock sensor is on the side under the intake manifold. The only thing I can think of on the exhaust side is the coolant drain plug (or in my case, the block heater). I suppose the guy who did the clutch job could have damaged it when trying to get at the starter bolt.
Old Jul 19, 2004 | 08:17 AM
S2000RAT's Avatar
Same crap with me. I had to buy a new knock sen. $178.00 I was pissed all because he wasn't watching were he was swinging the wrench.
RAT
Old Jul 19, 2004 | 01:40 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Make them fix it...only way to mechanically damage it is with a wrench. I'm with Xv on the fact that it was prolly damaged while accessing the upper starter bolt.
Old Jan 10, 2005 | 09:01 AM
revhard turbo s2's Avatar
my turbo s2 keeps throwing knock sensor codes what do i
do
Old Jan 10, 2005 | 09:05 AM
S2000RAT's Avatar
You should see if the sensor is broken off, you will have to get it on a lift. it is between cyl.2 and3 drivers side. . Mine was and it keep throwing the knock code.
RAT
Old Jan 15, 2005 | 07:42 PM
sanee515's Avatar
i was installed my oem exhaust on my car today and after the check engine light came on. is that because i possibly hit a sensor somewhere? if so where. and also i did not put in the exhaust gasket yet (because i lost mine) could that be the problem?
shawn
Old Jan 16, 2005 | 07:10 AM
Billman250's Avatar
Top Answer: 1
If your talking about the gasket between the header and the head, I'm not sure that's your problem with the cel. BUT, you can do major damage to the head without a gasket, by overheating it.
You probably snagged an O2 wire
Best advice...don't drive the car, get the gasket
Go to Autozone or something and get a cheap OBDII code reader. They may even do a quick scan for you for free.
Don't reset the ECU, it won't fix anything.
Old Jan 16, 2005 | 09:46 AM
alexf20c's Avatar
BTW, AutoZone always pulls codes for free.
a.sunnucks
Jan 18, 2014 05:58 AM
eddi3
Sep 27, 2010 12:10 PM
s2kbtos
Jul 5, 2010 06:04 PM
Dan Norton
Oct 9, 2009 06:16 AM
WI4FEN
Sep 10, 2007 10:52 AM
