Engine overheating from idling
Old Dec 5, 2003 | 11:16 AM
  #21
honda9krpm's Avatar
I think you most likely have bubble in you cooling system.
This prob sat on your fanswitch and cause error reading the temp (ie lower than what it should be) and caused overheating.
Try flushing the bubble out.
The other thing you should check also is your fanswitch relay.
Good luck
Old Dec 5, 2003 | 11:53 AM
  #22
Gernby's Avatar
Former Sponsor
Just fill it to the max marker with distilled water.
Old Dec 5, 2003 | 11:56 AM
  #23
amongmany's Avatar
You talkin' to me?
Old Dec 5, 2003 | 12:06 PM
  #24
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by munckee
Old Dec 5, 2003 | 12:08 PM
  #25
amongmany's Avatar
All it takes is distilled water? Is that the coolant reservoir?
Old Dec 5, 2003 | 12:15 PM
  #26
Ron Jeremy's Avatar
Can I full the resevior back to the full line with Honda coolant? Or do I need to mix it with distilled water?
Old Dec 5, 2003 | 01:46 PM
  #27
Road Rage's Avatar
Friend, adding plain water to a tank in Oklahoma in winter is crusing for a cracked overflow reservoir, or at least diluted coolant.
I think given the nature of your questions that you should go to a Honda dealer, buy a gallon of Type 2 coolant, and fill the reservoir to the point shown in the manual.
Get in your car, point it nose up on a small incline, start the car, turn on the heater, and let the car warm up - then cut it off when you are done, let it cool, and check levels again. This should remove any residual air, makes sure you have a safe fill, and get you all shipshape.
Old Dec 5, 2003 | 01:47 PM
  #28
amongmany's Avatar
So we shouldn't add water? What's the right answer to this? I just wanna know what goes in the tank!
Old Dec 5, 2003 | 02:27 PM
  #29
Intrepid175's Avatar
Old Dec 5, 2003 | 02:54 PM
  #30
ItalianBucwheat's Avatar
I had the same problem with two other cars. Both cases it was the fan switch relay!
