engine removal with the head off?
Old May 18, 2009 | 05:11 AM
supahman04's Avatar
Originally Posted by Slows2k,May 17 2009, 02:00 PM
If you want to lower the engine on the subframe you need to have a way to get the car over the height of the trans/engine while still attached to the subframe. You'll also have to disconnect the lower ball joints and front swap bar brackets, and steering rack pinion coupler to remove the subframe from the car.
IDK about doing all that. I never took the ball joints or anything apart. Just the steering colum off the rack.
Just drop the subframe enough to get to the top trans bolts and use a long extention. Shouldnt take more than a couple hrs.
If you need more guidance look up cmnsnse's write up on "replacing the clutch" in the diy forum. It is extremely detailed and has pics.
BoostMeUpScottyS2k
Nov 21, 2015 11:51 AM
omar_sanchez01
Oct 8, 2012 06:10 AM
ChefJ
Jun 11, 2010 10:19 AM
GoFaassttt
Oct 7, 2009 07:57 AM
natureal
Apr 17, 2006 07:49 AM
