Engine revving while on Neutral
Originally Posted by saucycg,Mar 13 2006, 04:51 PM
I took it to the dealer where they were kind enough to charge me $180 to run diagnostics, which revealed no error codes! I was pretty pissed that I blew almost $200 to have them tell me the car is fine when I know it's not.
I was hoping to find some info on s2ki so I can tell them how to fix it next time it happens. I found another thread or two that seemed to have similar issues and it looks like they had problems with their IAC valves or something....
Is your car stock?
Originally Posted by Incubus,Mar 13 2006, 04:56 PM
...and, like so many, he is ignoring the problem. Now that it is hidden and hasn't returned, he doesn't care anymore. It pays to take care of business in this case.
Yeah, 2003 S2k (50k miles) totally stock. I've got a 5/75 extended warranty and I want to make sure this is fixed while under warranty.
I didn't realize that the code goes away once the CEL is out. Bummer for me and my wallet!
Originally Posted by Quivers,Mar 13 2006, 04:14 PM
check your coolant level, that can cause an irradic idle. I cant believe you paid honda to look at your car...
I've seen erratic idle on some other Honda because of low coolant level. I know it sounds hard to imagine the connection between coolant level and erratic idle but that's why this culprit is often missed. With low coolant level, the fast idle valve is not flooded with hot coolant all the time. The time air pocket surrounds the valve, it thinks that it's cold enough to trigger fast idle, thus the jumping engine speed. If not that, I would say the IAC, especially when ECU logs a CEL. It has to be intake air related or bad ECU that drives the IAC valve incorrectly, because no amount of fuel/ignition alone can raise engine speed that high.
Well my S2000 did it again this week. This time I went to autozone and they let me borrow an ODB-II reader. Took about 2 minutes to pull the code. I can't believe that I got robbed of $180 by my honda dealer to do the same thing. I guess I learned my lesson there.
Anyway, I used an Actron CP9135 ODB-II reader and pulled the following code:
P1519
The scrolling text on the bottom read:
"Manf Cntrl Veh. Spd. Idle Speed Control Auxiliary Inputs"
P1519
tokyo_james
Apr 11, 2004 08:20 PM
