Engine ringing noise under load
Old Jul 15, 2012 | 07:29 AM
RobEvans's Avatar
Default Engine ringing noise under load
Hello, im getting a metallic ringing noise from around 2000rpm up to 3500rpm with around 50% throttle.
Its quite a high pitched noise and i cant replicate it while parked up to help me find it. Could anyone give me some ideas for what to check?
Im selling the car so i want the car in 100% mechanical condition before sale. Thanks Rob
Old Jul 15, 2012 | 10:55 AM
zestmyu's Avatar
Not sure what's causing it but I'm having the same problem.
Old Jul 15, 2012 | 05:32 PM
s2klariat's Avatar
Kind of sound like a cricket? Possible bad PCV valve or could just be basic intake noise. A lot of S' do it, mine included.
Old Jul 16, 2012 | 02:23 AM
RobEvans's Avatar
Thanks for the reply, I found this thread... https://www.s2ki.com/s2000/topic/386...e-at-take-off/
I'll change the pcv anyway. Thanks again
Old Jul 16, 2012 | 04:57 AM
stezie's Avatar
i had a noise, in similar circumstances as you mentioned. I found out that I was missing a bolt from the exhaust manifold heat shield and another one was loose. might be worth checking all your heat shields underneath your car to make sure they are secure..
Old Jul 16, 2012 | 08:01 AM
RobEvans's Avatar
Will do this weekend, thank you
Old May 21, 2014 | 06:30 PM
Hakkaboy's Avatar
Did you find out what the issue was?
Mine just starting to behave this way today.
I feel like this "metallic" noise only comes on when i'm driving slightly slow in a higher gear and then I step on the throttle to about 50%.
Kinda like how you can "charge up" the intake noise? This is when it happens. I checked the hoses and they all seem to be tight.
I will check the bolts later on
Peeves
Oct 17, 2015 08:46 AM
mikefifth
Dec 17, 2013 08:04 AM
thewiseboatmaker
Jul 23, 2009 08:42 PM
BlueSTwoK
Feb 24, 2005 04:16 PM
Carlson
Mar 23, 2003 11:57 AM
