Engine shims?
Old Dec 1, 2015 | 05:59 AM
baZurk's Avatar
Figure out what alternator they put on that car. A new OEM Honda alt. is very expensive, so if you didn't $600 for the part, it is likely they put a cheap replacement on there. This issue you are having could be related to the TCT, idler gear, or inadequate valve clearances. Is the motor stock? I agree with everyone above, find someone else to help you out that knows more about the s2000
Old Dec 1, 2015 | 09:18 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Running the engine for 10 seconds without the belt will confirm all belt driven sources are (or are not) your problem.
The amount of bad alternator bearings I have seen or read about in an S2000 in 13 years is zero.
There are no such thing as engine shims in an S2000.
I wouldn't pay for your repair until you actually confirm the car is repaired.
If the repair shop says we can't give you the keys until the bill is paid, ask to be taken for a ride in the car.
Old Dec 1, 2015 | 01:31 PM
Soviet's Avatar
Thank you based Billman.
booost02
Jun 21, 2013 12:12 PM
sillydrew
Dec 16, 2011 10:01 PM
Green Tea
17
Apr 18, 2007 08:10 AM
Shaggysatx
Apr 2, 2007 06:41 AM
Formula
Jun 27, 2006 07:15 PM
