Engine skipping under load.
Old Aug 14, 2013 | 10:57 AM
schwissig's Avatar
Default Engine skipping under load.
Hello. I have a year 2000 (100% stock) and I just started having this problem with the car. The engine will skip under moderate-to-heavy acceleration, but it runs fine at idle and when revving in neutral. There is not a check engine light. After a bit of investigation, I think it might be the MAP sensor. I also think that there is an engine clicking (at least at idle, cold and warm) that was not there previous, which makes me worried that it could be a bent valve. I have not checked anything out yet, but I plan on it this afternoon.
EDIT: It might be important to note that I didn't shift in time 2(ish) days ago, and hit the rev limiter. I have read that over revving can cause valves to bend? How common is this? I have not misshifted.
Some questions I have:
- Would a bent valve cause the engine skipping while under load and not when revving out of gear?
- What tests should I perform first?
Thanks for your help in advance.
Old Aug 14, 2013 | 11:07 AM
pmptx's Avatar
clicking/ticking-search under TCT-timing chain tensioner.
The skip may be the MAP, search MAP whack and zip tie that thing
Old Aug 14, 2013 | 04:22 PM
Billytehbob's Avatar
Hitting the rev limiter won't cause you any issues, as you can over rev that way, you can only do it mechanically via a mis-shift.
Old Aug 14, 2013 | 09:07 PM
schwissig's Avatar
Problem Solved! I took the map sensor off, wiped off the rubber seal, and then put it back on (nice and snug). I also zip tied the electrical connector to the MAP sensor. While I was doing that, I noticed that the throttle cable was very loose, so I tightened that up (Not "tight", but "taught". I heard it should have about a 4mm sway from sided to side.) One of those 3 things fixed it. I didn't even "whack" the MAP, so I don't think that was it. It was probably the throttle cable, since it was quite loose, but I don't understand how a loose throttle cable would cause the engine to skip when under load. If it was for some reason the MAP, I read that this problem could return soon, so if it does, I'll post back. I haven't checked out the TCT yet, but I will soon. The main problem is fixed anyway, shes running smooth again.
Thanks for your help. I was worried it could have been something serious for a bit there.
yourboysoap
Jun 24, 2011 06:52 AM
Justin Yoo
Aug 1, 2010 09:58 PM
supahman04
Jun 22, 2008 05:13 PM
S2kRod
Oct 19, 2004 09:17 AM
alexchou
Dec 23, 2003 06:03 AM
