Engine/ Transmission bolt pattern specs
Old May 11, 2009 | 09:54 PM
RUEHL925's Avatar
Default Engine/ Transmission bolt pattern specs
I need the measurements of the transmission bellhousing bolt pattern, or the back of the engine measurements where the tranny bolts on. Been searching for it, but cant find it. We need it to make a adapter plate, and will save the machine shop some time knowing the exact specs of each bolt hole in relation to the center of the crank. Thanks!
Old May 12, 2009 | 02:49 AM
lotus7racer's Avatar
Considering someone will give you the measurement, will you trust?
It's a specialty machine shop job, you can't mess around.
I think you need to find a friend who has a spare and accurately measure the pattern.
Old May 12, 2009 | 04:07 AM
Bugs2k's Avatar
or just get with inline pro they have already made adapter plate to adapt k series trans.
Norccer
Aug 1, 2018 01:08 PM
krosfyah01
Jun 24, 2016 02:41 PM
c130turboprop
Nov 26, 2013 03:34 AM
skibum
Sep 29, 2007 05:50 PM
GDM S2K
Dec 26, 2006 08:57 AM
