Engine trouble?
Old Nov 15, 2005 | 03:09 AM
mknightx's Avatar
Default Engine trouble?
I hear a faint tapping noise when at idle. I have over rev'd once in the past (5th to 2nd deal) and now I think its catching up to me. From my vauge description can the experts here guide me to what may be causing this tapping type noise. I think it may have something to do with the valves after reading some of the stuff in this section but I am not 100% sure. Any feedback would be greatly appreciated.
Thanks
Old Nov 15, 2005 | 10:18 AM
DOUGHS2K's Avatar
A big key is if you are throwing a CEL light.
If you are not than I would make sure your oil is full enough and that isn't your rods knockin down there.
If it is full, than your valve cover will need to come off.
Take a look and seeif there are any scoring marks and if the valves are in equal length which each other.
I had one exhaust and one intake valve on the #4 cylinder sit almost half an inch above all the others when my engine blow.
Good luck and take care of it now before things get worse.
Old Nov 15, 2005 | 02:57 PM
mknightx's Avatar
Thanks Doughs2k... I shall check out the things you mentioned.
Mooseman
Feb 20, 2018 09:32 AM
FormulaStwoK
Mar 8, 2012 01:10 PM
nashby
May 6, 2008 12:35 AM
Spec_Ops2087
Jul 17, 2006 11:39 AM
Spec_Ops2087
Jul 13, 2006 02:35 PM
