Entire shifter spins...
Old Apr 20, 2017 | 06:21 AM
bkowa092's Avatar
Default Entire shifter spins...
Last year at some point I had to remove my shift knob that was on with lock-tite. After fighting with it for a few minutes I finally got it off. I noticed my shift knob was spinning after this and just wrote it off as being stripped. However, the other day I realized it is not just the shift knob that spins, but the whole entire shifter spins with it.
Has this been damaging my car at all with this not being "locked" in place over the past year? How can I fix this?
Thanks guys and gals.
Old Apr 20, 2017 | 06:58 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Sounds like the rubber in the shifter has separated.
Pull the console off, see what's spinning and what's stationary.
Old Apr 28, 2017 | 10:41 AM
bkowa092's Avatar
Billman,
Thanks for the reply. Got around to taking the console cover off and found that the metal shaft is separated from the rubber bushing part (as you guessed). Here are some pictures to make sure we are talking about the same thing:
Is there anyway to replace this whole part?
Old Apr 28, 2017 | 10:49 AM
Car Analogy's Avatar
An adhesive of some kind?
You can certainly just get a used, complete shaft. From the threaded end the knob screws onto to the opposite end that fits into the trans with the white plastic swivel. Just bolts in.
But I should think the right adhesive would be faster, cheaper, easier. Worst case it doesn't work and you have to find a used shaft anyway. So worth a try with glue.
Old Apr 29, 2017 | 07:42 AM
bkowa092's Avatar
Good idea! A little JB Weld should do the trick.
Old May 1, 2017 | 03:15 PM
Billman250's Avatar
Top Answer: 1
That shifter is some aftermarket junk, not oem.
Just get an indestructable new or used oem shifter.
Old Aug 24, 2022 | 08:30 PM
jaykobean's Avatar
@bkowa092 How were you able to fix this issue? I ran into the same issue today after attempting to remove my shift knob .
Any chance you can give me clear steps on what you did?
Old Aug 25, 2022 | 10:32 AM
B serious's Avatar
KillerBlackbird
Jul 17, 2013 10:07 PM
mirabileboy
Oct 18, 2012 02:44 PM
mse678
Feb 16, 2011 11:04 PM
jason_v2
Dec 18, 2009 11:25 AM
dozen5
Jun 30, 2005 04:00 PM
