EPS
Old Jul 1, 2009 | 06:57 PM
AusS2000's Avatar
Default EPS
I haven't had power steering in my car for some time now. Finally found the time to have a look at it this weekend. I have the Service Manual and it say to use a volt meter to check for certain states. I'll do this Saturday.
In the meantime, does anyone have any experience with this? What sort of things go wrong? EPS motor? Control box? Torque sensor? Fuse? (I checked the 70amp fuse and it looks fine).
I am running the AEM EMS so no EPS light or diagnostic code.
Any help would be appreciated.
Old Jul 1, 2009 | 07:04 PM
Slows2k's Avatar
Have you unplugged the EPS control unit recently?
There are 2 plugs to the control unit which can be plugged in in the wrong socket and you'll have no assist.
Old Jul 1, 2009 | 07:06 PM
AusS2000's Avatar
Hmmm, I haven't but I'll check that out.
Old Jul 1, 2009 | 07:13 PM
Slows2k's Avatar
If it doesn't work now, flip the plugs and see if it works.
You can trick the HDS to work with a AEM car, but it requires another stock S2k to get past the 1st diagnostic screen. The SCS short should still flash EPS DTC's through the cluster.
Old Jul 1, 2009 | 07:35 PM
AusS2000's Avatar
Are you saying the SCS short is independent of the ECU?
I have considered plugging im my old ECU and getting the code if there are any but I'm guessing it will just tell me EPS Fail and not actually help much.
BTW, I picked up a replacement steering rack recently just in case.
Old Jul 1, 2009 | 07:55 PM
Slows2k's Avatar
SCS on a US spec car will still work with a EMS.
Old Jul 2, 2009 | 05:22 PM
Slows2k's Avatar
You mess with it any?
It is EPS control unit connector A and C that can be reversed.
Old Jul 2, 2009 | 05:35 PM
AusS2000's Avatar
Nah not yet. Saturday morning.
Mechanicking is just a hobby for me. I have a real job that finances my addiction.
Old Jul 2, 2009 | 05:36 PM
Slows2k's Avatar
It's 2 plugs to swap.. It's also my best idea for transcontinental troubleshooting.
Old Jul 2, 2009 | 05:54 PM
AusS2000's Avatar
Ok, just checked.
I can't even plug it in the wrong way around. The harnesses don't reach.
