EPS Issues - Light on, no power steering
Old Dec 22, 2007 | 06:32 PM
stantaur's Avatar
Default EPS Issues - Light on, no power steering
I have cleared the codes on my EPS diagnostics, replaced the EPS box (passenger side in engine bay by battery), checked all connections and still get no power steering. Welcome any thoughts you might offer.
Car has AEM ECU (which has worked perfectly with Pwr Steering for years).
Thanks,
Stanford
Old Dec 22, 2007 | 06:44 PM
Slows2k's Avatar
There are 2 plugs that can be reversed on the EPS unit, flip the connectors and re check.
Old Dec 22, 2007 | 10:03 PM
dbzerk's Avatar
Is there any problems with your speedo cluster?
I had a mate that had an issue with his speedo cluster and that affected the EPS....
Old Dec 23, 2007 | 10:20 AM
spectacle's Avatar
check your voltage...make sure you're making the power the EPS system needs to function
should be 14v with the car running
Old Dec 26, 2007 | 09:24 PM
stantaur's Avatar
Yes, connectors are correct and I have ~ 14 volts when the engine's running. Other ideas?
Thanks,
Stanford
Old Dec 26, 2007 | 09:38 PM
cthree's Avatar
Administrator
I also vote that you've reversed the two EPS cables on the controller box. That or you have a loose connection elsewhere.
Old Dec 26, 2007 | 10:02 PM
Stratocaster's Avatar
Just a guess, but did you reset the EPS Torque sensor neutal position sensor? That does make the steering feel really heavy. Almost like it is off.
speedzx
Feb 28, 2017 11:27 AM
rikhemi
Dec 17, 2014 04:33 PM
Ridla
Jul 10, 2012 12:23 AM
gti2000
Feb 24, 2006 06:43 PM
zking786
Aug 6, 2005 06:28 PM
