eps not working
Old Aug 18, 2013 | 10:21 AM
DiDriver's Avatar
Default eps not working
Hi guys!
I would appreciate any help!
Im loosing my eps. Codes 3 and 32. 32 goes away after reset with 4,9 pin conn-s in obd port. Code 3 is still actual. Some times it working and the light is not flashing, but next time when im starting engine its back.
Also ive already check connectors in drive column and eps control unit.
What is can be?
Old Aug 19, 2013 | 04:08 AM
DiDriver's Avatar
Today ive check the codes again and the can say that 32 comes back.
Any ideas?
Replace the control unit?
Old Aug 19, 2013 | 07:59 AM
End005's Avatar
I used to have a lot of issues with my EPS. When it was hot out, it would act up. But, it comes and go. I finally replaced my EPS unit and it worked perfectly fine ever since. I got my unit from a local here who turned his AP1 full race.
Good luck! Search because you'll find a ton of solutions. EPS going out is pretty common apparently.
Old Aug 19, 2013 | 08:01 AM
xLostx's Avatar
You don't happen to have the yellowjacket speedometer add-on do you?
Old Aug 20, 2013 | 01:40 AM
DiDriver's Avatar
Guys thank you for help!
Problem solved by replacing the eps control unit))
Hope to forget about it for a long time))
Yellowjacket?)
What is it?
Bigchief
Mar 12, 2015 05:22 AM
CR1S
Mar 7, 2014 10:03 AM
joelrevans
Sep 15, 2013 08:26 AM
Jimmy Roadster
Sep 4, 2012 12:59 PM
