EPS problems
Old May 7, 2018 | 05:55 PM
ZachS45's Avatar
Default EPS problems
I recently started having eps problems where either its on or off randomly and now torque is uneven steering right to left. The first time i had it happen was a pot hole that jolted the car and the eps shut off. Since then it has gotten worse and more random. Ive searched and searched but i dont think the reset trick is going to fix the problem. Is it possible the eps box is damaged from the pothole or could it be faulty connections in the plugs themselves. i only extended two wires to the power steering motor itself and those connections are fine. so im pretty sure it has to be something else.
Old May 8, 2018 | 02:52 AM
Slowcrash_101's Avatar
Ap1?
Old May 8, 2018 | 03:49 AM
ZachS45's Avatar
Originally Posted by Slowcrash_101
Ap1?
Ap2 05
Old May 23, 2018 | 06:15 AM
Badlilwezel's Avatar
I have the same problem it pops up code 14 and 35 which are faulty grounds check those out and see if you have continuity. This will help you out too.
https://issuu.com/onderhoud/docs/honda_s2000__00-03__service_manual02
bsheep83
Mar 13, 2013 06:53 PM
darob112
Sep 13, 2012 05:02 AM
ZiTrO
Sep 16, 2011 07:04 AM
ndk4
Oct 11, 2010 01:13 PM
nexus
Jun 9, 2007 03:44 AM
