Erratic Speedometer
Old May 26, 2016 | 02:27 PM
homersapiens's Avatar
Default Erratic Speedometer
My speedometer frequently (>50% of the time) operates in an erratic manner with the reading flickering from one random number to another. Cruise control will work during the few periods the reading is more or less stable, but obviously it can't follow when the erratic numbers start flashing and it kicks off. Sudden transitions seem to make it worse.
I searched this topic on the forum and the suggestions were (in my order):
1. Disconnect battery for at least 5 minutes
2. Check engine, firewall grounds for tightness
3. Replace speed sensor
4. ??
I have gotten to step 3 without success.
My shop - who is talking to Honda - is researching it. Presumably, it will require replacing the "main computer" - which I call the ECU - or the instrument cluster. I am ashamed to admit I don't know if these are distinctly separate units, but it seems I read somewhere they are integrated.
I am interested in hearing from anyone who has experience with this problem or knows about it. Apparently it's not a wide-spread problem but I am not the only one who has experience it.
As an aside, I'd like some suggestions on getting a good Factory/Repair manual. I am inclined to order the official Honda manual, even if it costs me.
Thanks in advance!
Old May 26, 2016 | 04:09 PM
kukudm's Avatar
Have you checked negative ground wire on the battery?
Old May 26, 2016 | 07:00 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Check the ground wire on the back of the cylinder head, it is the number one cause of erratic speedometer issues.
Old May 27, 2016 | 03:36 AM
freq's Avatar
Dude never ceases to amaze me. Assuming he's right.
dv55xc
Apr 11, 2017 10:33 PM
PhAtXSuMo21
Jan 7, 2009 05:48 PM
CiderBoy
Jan 22, 2007 05:02 AM
REV_29K
15
May 27, 2005 03:06 AM
VR WHAT
May 30, 2002 01:39 PM
