F20C with Ap2 Ecu?
Old Jan 3, 2007 | 01:14 AM
F20CAP2's Avatar
Default F20C with Ap2 Ecu?
I recently had an F20c dropped in my Ap2. I am currently running an AEM EMS but cant get the car started. I want to make sure that the problem is not the EMS and want to try to start the car with the Ap2 Ecu. Should it start up fine or would I cause damage if I had the shop try it? Ive searched and all I can find are topics of Ap2's with Ap1 Ecu's.
Old Jan 3, 2007 | 04:37 AM
Dark's Avatar
what year AP2 ecu ('04 if its the listed s2k of yours)? 2006+ is drive-by-wire.
Also, unless the AEM will bypass it you will be stuck with an 8.2k redline.
Old Jan 3, 2007 | 06:28 AM
Elistan's Avatar
I can't imagine any reason why starting an F20C with an AP2 ECU would be anything to worry about. Fuel tuning would be a bit off, but not enough to hurt anything during a "can it start and idle" type test.
So, IMO, put your OEM ECU back in and see if it'll fire.
Old Jan 3, 2007 | 07:19 AM
Stratocaster's Avatar
I agree. It would be a valid test to rule out the ECU (EMS) as the source.
Old Jan 3, 2007 | 05:13 PM
F20CAP2's Avatar
Thanks for the reply guys. The shop used the Ap2 ecu and the car fired up fine. The problem is with the EMS.
beaudin223
Sep 6, 2017 06:15 AM
Disos2k
Jul 10, 2013 06:18 PM
F22AP1
May 30, 2011 11:46 AM
Jimboner
Aug 24, 2009 08:28 AM
prodriverex
Aug 17, 2007 08:20 AM
