flywheel
Old Nov 1, 2007 | 03:32 PM
s2kbtos's Avatar
Default flywheel
hello... i'm doing my clutch on my s2k, i took everything off but a 17mm or 18mm socket doesn't fit on the bolts. what can i use to take them off? i'm pretty much stuck there...
Old Nov 1, 2007 | 03:43 PM
300sx's Avatar
Are you trying to use a 12 point or 6 point socket??
Old Nov 1, 2007 | 03:55 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
17mm, 12 point socket. It must be ground flat or you will likely strip the bolts.
Socket on the right is ground flat.
Old Nov 1, 2007 | 04:06 PM
s2kbtos's Avatar
ok, thanks i really appriciate your help. so just to make sure, its a 12point 17mm socket ground flat, not the deep socket.
Old Nov 1, 2007 | 05:41 PM
Slows2k's Avatar
Must have a 12 point socket. Don't grind the socket off square.
Old Nov 1, 2007 | 06:19 PM
s2kbtos's Avatar
ok, since i had to go buy the socket, now is dark and i cannot see anything, so do i just put a screwdriver between the flywheel teeth to stop it from spinning? i dont have a grinder to do that, i hope it doesn't strip. oh btw i have a fidanza flywheel and i'm putting my stock flywheel back on.
Old Nov 1, 2007 | 07:11 PM
Slows2k's Avatar
Buy an Impact wrench. It's your next best friend for things like this.
Old Nov 1, 2007 | 07:43 PM
skibum's Avatar
Sometimes in life, 2 is better than 1. Such as 2 girls in the bedroom. Other times in life, having 1 of something is better. Such as a flywheel.
Old Nov 1, 2007 | 08:51 PM
IlleztImportz's Avatar
it may be better to have someone hold the front of the crank, but if u have to screwdriver may wrk, make sure is a nice n strong one
Old Nov 2, 2007 | 04:06 PM
s2kbtos's Avatar
how would i remove thebearing from the flywheel? like the little one i also want to replace that.
hambler
Jun 28, 2016 01:35 PM
ghosta9
Apr 5, 2015 05:40 PM
TexaS2OOO
Jul 16, 2007 06:54 PM
cdelena
Oct 10, 2002 06:18 AM
