Front Brake Pad Replacement
Old Jul 3, 2007 | 07:44 AM
gosixers215's Avatar
Default Front Brake Pad Replacement
I'm going to replace my front brake pads once they come in from HTG and will follow the DIY in the sticky. I wanted to know if anyone had pics to accompany the DIY? It'll be my first try at this and wanted to have as much visual help as possible.
Thanks!
Old Jul 3, 2007 | 08:27 AM
Kenpo_S2000's Avatar
Pics for the rears would be great too, I will be tackling this soon also.
Old Jul 3, 2007 | 12:13 PM
N2oExpresS2k's Avatar
I would show you the pictures, but I'm a berlina and dont care for yellow =p! j.k. I'd show you the pics if I had taken them even tho you drive a spa =/.lol It's really easy. Just follow the diy and make sure you're very carefull when you depress the piston back into the caliper so you dont break the seal. Take off the cover on the brake master cylinder too..
Old Jul 3, 2007 | 12:18 PM
Gatsbee13
Guest
Posts: n/a
are you getting the front rotors resurfaced as well? i heard this has to be done when replacing pads.
Old Jul 3, 2007 | 12:23 PM
90crvtec's Avatar
That depends on how worn your rotors are. People resurface a rotor because it's either warped or because it has been in use for so long that the old pad has cut a groove into the rotor, this can cause issues when trying to bed in new pads.
If your rotors are not warped and if they are in good shape (very little wear) then just throw some new pads on there and call it a day. Resurfacing a rotor removes material from it, this essentially makes it less effective (less rotor material means less surface area of heat absorption/dissipation). I wouldn't resurface them unless you have to and if you have to, I'd start seriously thinking about just buying a set of new front rotors. The cost is minimal and brakes aren't something you want to skimp on.
Old Jul 3, 2007 | 12:24 PM
iam7head's Avatar
make sure you have a impact driver, the phillip counter sunk screw ain't gonna come out with a screw driver.
Old Jul 7, 2007 | 02:12 PM
Just did this today for the fronts only and didn't need pictures. The DIY was very clear and helpful. The hardest part was loosening the lower bolt that holds the caliper in place. Plenty of WD-40 and muscle took care of that. The whole thing for one side from wheels off to wheels on probably took me 20 minutes, if that.
SDueces
Mar 2, 2014 09:24 PM
Pee-Nut
Aug 26, 2013 03:00 AM
craig2teg
Jul 29, 2008 08:35 AM
replicah
Jul 20, 2007 12:20 AM
jojipoji
Feb 4, 2003 06:49 PM
