Front clunk noise!
Old Jul 27, 2004 | 11:44 AM
Proper Bo's Avatar
Default Front clunk noise!
Ok, dont think this is the fwd/reverse problem i've seen on here or brakes either, basically when i pull away in 1st gear i hear a clunk coming from the front driver wheel and now and again when i slow down. I doesnt do it all the time jus when it feels like it.
Any ideas?? What is this bonnet catch problem i hear about?? Is that it
my email is - niw756@fsmail.net
for your feewback will be greatly appreciated
Old Jul 27, 2004 | 05:40 PM
xviper's Avatar
Not much to go on. A "clunk" from the front corner could be almost anything. If you can duplicate it at will, get it checked out by the dealer. It could anything from a forgotten spring spacer, to a bad ball joint, to a bad control arm mount, to a loose sway bar mount, to a bad shock.
Old Jul 27, 2004 | 06:15 PM
dreamcation's Avatar
Smile
I have the same problem but when I'm in reverse and come to a stop. This use to happen to my Civic all the time and the dealer said it was normal, yeah right
Control arm or ball joint would be my best guess for what I got going on.
Old Jul 27, 2004 | 08:43 PM
Nobody's Avatar
You don't happen to have a Saner bar, do you?
Yeah, sounds like something in the suspension isn't bolted down tight enough. Easiest thing to do would be to pull the wheel off, grab a torque wrench and make sure everything is torqued to the right spec.
By any chance--any recent work you had done to the front?
Old Jul 27, 2004 | 11:38 PM
Proper Bo's Avatar
It doesnt duplicate all the time but does is from stationary going forward i.e. 5 mph, then now and again when slowing dwon (but rarely).
No work done to it, its just developed this past few days and is a bit worrying.
Out of interest how much are these various part to replace i.e. ball joint, suspension parts etc, if it is this??
I will take the wheel off the weekend and check the suspension and let you guys know.
kgregg
Mar 13, 2017 11:30 AM
BenWise04
Aug 17, 2015 05:21 PM
s2krxx
Jan 17, 2014 09:52 PM
dan_uk
Dec 3, 2008 05:31 PM
LegendaryHarry
Jul 21, 2007 12:43 PM
