Top not going down all the way.
Old Jul 19, 2007 | 11:27 PM
LegendaryHarry's Avatar
Default Top not going down all the way.
i dont think my top is going down all the way.... it kinda just happend suddenly....
help? or is it really down all the way and im just crazy
Old Jul 19, 2007 | 11:29 PM
tekstar's Avatar
http://www.modifry.com/products/index.htm
see if this helps.
you can try physically pushing the bar down. lower your top halfway, then push the the bar that is held by the straps down, then lower your top. if this works then you need modifry's straps
Old Jul 19, 2007 | 11:46 PM
okay pushing the bar down helped. then i tried it again with out pushing and it worked again.
so fixed.
least i know what it could be next time.
thanks
Old Jul 20, 2007 | 01:44 PM
2poor2mod's Avatar
not really fixed. it may work one or two times but the straps are worn out and stretched and need to be replaced in order to properly fix the problem.
Old Jul 20, 2007 | 03:48 PM
S2000Patrick's Avatar
Straps are stretched. I have to push that bar down each time I lower the top. I've thought about fixing it but the motion of pushing the bar is so routine now I don't even think about it.
Old Jul 20, 2007 | 11:11 PM
soslow64's Avatar
Originally Posted by S2000Patrick,Jul 20 2007, 04:48 PM
Straps are stretched. I have to push that bar down each time I lower the top. I've thought about fixing the straps.
Next time you are over here in AZ, just stop by the shop. I can put some new straps on if you are willing to wait in the lounge and drink our Starbucks coffee. Or you can stand by the door and watch. But it is about 110 everyday, so that might not be advisable if you dont like the sun.
-Cesar
Old Jul 21, 2007 | 09:52 AM
clag's Avatar
Be aware that the bar not retracting causes the top to stretch tightly against the latches. Many a story like this ends with "The top hung up for a second and then I heard a ripping sound. Now I have a torn top".
Get some new straps from Modifry or another source, untill then, move the bar back by hand. Continued testing or forcing the top will likely damage it.
Old Jul 21, 2007 | 12:43 PM
Wildncrazy's Avatar
Yes, 2 fist sized holes just behind the catches.
REPLACE THE STRAPS INSTANTLY!!!!!!!!!!!
duhelo
Feb 12, 2016 09:21 AM
DrivenAP2
Jun 20, 2014 02:30 AM
SoCalIsMyLife
Aug 4, 2007 01:46 PM
WarrenW
Jun 28, 2005 10:24 AM
SC_Highlander
Jan 12, 2004 11:26 AM
