Fuel Cap Code and Gas smell after Koni Install
Old Oct 2, 2016 | 09:40 AM
Medicise's Avatar
Default Fuel Cap Code and Gas smell after Koni Install
Hello.
Help!!
I've installed and removed shocks multiple times, but after installing my Konis a while back, I get:
1) "Fuel Cap" code on Odometer screen
2) Slight gas smell.
I replaced the Gas cap with OEM from Honda, reset the code and it came back. Still smell gas too,
No gas leak obvious from anywhere, including all around the Gas fill neck that I moved out of the way when installing the Konis.
I have not removed the rubber cover that covers the rubber tubes connecting to the fuel tank yet.
I'm thinking maybe the seal of the metal part of the fuel neck was misshapen during movement.
What do y'all think?
Thanks!!!
Old Oct 2, 2016 | 12:31 PM
Nyther's Avatar
Check the release cable from the fuelcap door?
There is usually no need to move the gas neck for a shock install ( pita! ) so IF you moved this part, there is a chance that it's not properly sealing right now.
Old Oct 2, 2016 | 01:58 PM
zeroptzero's Avatar
Yeah one of the vent hoses must be loose on the fuel fill pipe, too much of a coincidence. Make sure all of the clamps and hoses are tight on the pipe, if I recall there is one screw clamp, if you moved it during the installation it might not be tight enough.
Old Oct 3, 2016 | 08:53 AM
Medicise's Avatar
Thanks Y'all!
I actually just threw a code for Evap leak. I don't have the service manual so I am a little weary to mess with everything.
I'll post my results when fixed
Old Nov 1, 2016 | 05:00 AM
Medicise's Avatar
It was the fuel neck move I did when installing my Koni's. I got a little to rough with and disconnected a connector inside the rubber boot cover. All fixed now.
Old Nov 1, 2016 | 05:30 AM
freq's Avatar
I removed that rubber boot cover to make shock adjustment easier.
RedCelica
Jun 13, 2016 04:22 PM
S2G4life
Jun 14, 2014 08:57 PM
wickwirew
Oct 11, 2013 06:03 PM
lopez14
Nov 15, 2012 10:02 PM
