Fuel cut/loss/limit under half a tank?
Old Jan 19, 2006 | 11:14 AM
iammike's Avatar
Default Fuel cut/loss/limit under half a tank?
I've had my car for about 6 months now. It is a 2001 model, has around 41k miles, and has never been wrecked (gas tank is stock and perfect). This is a bummer cause I'd like to take it out autocrossing once or twice this next season.
The issue: Whenever I'm at or under half a tank of gas (approximately), the car will sort of stall out when I pull a u-turn hard, do a doughnut, or even accelerate spiritedly (this occurs when I'm closer to E). What is funny is it doesn't actually stall; the motor idles fine, it is more like the ECU is cutting off my throttle input... The car just won't go.
I have yet to check anything because I'm not even sure what to check. Hell, my Civic doesn't starve on r-compounds at the racetrack (far higher g-forces than I'm making in the S) when it has 2 gallons left in the tank.
Any ideas? Weak/bad fuel pump? Dirty filter (highly doubtful)? I'm lost, any help would be greatly appreciated.
Old Jan 20, 2006 | 03:46 AM
jguerdat's Avatar
There's a well-known starvation issue with the S for autocrossing, especially with sweepers. Some of us have run into it with well over 1/2 tank. Other times an almost empty tank is fine.
You might wanna search the Racing and Competition forum for more details.
Old Jan 21, 2006 | 07:04 AM
Slows2k's Avatar
Moving to UTH
Old Jan 21, 2006 | 09:34 AM
llthomps's Avatar
Hey, I'm having the same problem. I also have a 2001 with about 33K and it stalls out when I'm under half a tank of gas and after it hits the V-TEC. When I push the clutch in and put it in second and let the clutch out the car stalls out and the RPMs kinda get stuck at about 5000. It just started happening about a month ago. I have no idea whats wrong with it and I really don't know all the technicalities of cars. I would really appreciate it if you let me know if you figure out what the problem is and I'll do the same.
Thanks!!
Lauren
Old Jan 22, 2006 | 08:28 AM
jguerdat's Avatar
Straight-line fuel starvation will be a different animal compared to while in a turn. You seem to mean that here so I'd surmise various things like fuel filter plugged, fuel pump not supplying enough volume, crimp in a hose or tube someplace, etc.
Old Jan 23, 2006 | 02:07 PM
doughNuts's Avatar
I have the same problem sometimes , PLease Help! im thinken its the ecu maybe , for some reason i think the 01 ecus suck but thats just a guess i dunno . Thanks-Adam
Old Jan 23, 2006 | 02:11 PM
rworne's Avatar
Just to chip in here:
2003, routinely driven until no bars (~2 gal and change left in the tank) before refueling and never had this issue during any kind of daily or semi-spirited driving or during vtec.
kenny_son
Apr 19, 2009 01:54 PM
Eric220
Aug 2, 2008 01:56 PM
jasonw
Aug 15, 2005 04:19 PM
s20009000
Dec 30, 2003 06:28 PM
jelliotlevy
May 1, 2003 11:15 AM
