Fuel draining
Old Apr 19, 2006 | 11:47 AM
Bassy's Avatar
Arrow Fuel draining
Hey,
I have a s2k which has been stood in the garage with just under 1 8th of a tank of petrol, when attempting to start this it was't happy, its constantly misfires
Will it be worth my while filling the car up with fresh petrol and trying run it until the fresh petrol reaches the engine, or is there a easy method of draining the petrol?
or bleeding the system through?
the engine will run but it is obviously misfiring, please help!!!!
The other option is to take it to the main dealer which has just ripped me off as it is!!
Any help would be much appreciated
Old Apr 19, 2006 | 12:21 PM
Wisconsin S2k's Avatar
How long did the car sit? How long did it sit without running?
How do you know it's misfiring? Are you getting a CEL or MIL?
Old Apr 19, 2006 | 01:09 PM
Bassy's Avatar
hey, it has been stood for 18months, i bought this car then had it transported home as i did not want to start the engine until the oil has been changed, I have quiclkly tried turning it over to see what the outcome was,
I was considering filling the tank with petrol to dilute and clear the old petrol out,
before doing this i wanted to check the best plan of action.
Sorry i don't quite know what you mean Cel or Mil?
the engine is turning over but rocking the car at low revs, once you increase the revs to approx 1500rpm the engine feels more steady but is clearly not firing, if you let the revs fall again the engine cuts out.
The car started to smoke at first but now turns over without smoke.
Old Apr 19, 2006 | 06:37 PM
gotswap's Avatar
"CEL" = Check engine light.
"MIL" = <alfunction indicator light.
Looks like a little motor and yellow on your display. If that light were on your could hook up a diagnostic unit to help determine what was actually going on.
You could just fill up your tank and let it mix but if that is not the issue you could be in trouble.
Did you buy the car with out test driving it?
Old Apr 20, 2006 | 08:55 AM
Bassy's Avatar
Unhappy
yeah stupidly enough, i didn't test drive it!
i trusted with its low milage it would be ok as it has only done 12miles
Honda plugged it in yesterday and the engine management determined it was bad fuel.
i think my best bet is to stop trying short cuts and take it to the main dealer, to drain the system down and get the car running.
what damaged may have been caused? the technician started the engine and advised to add a full tank of fuel to override the stale stuff but after running the car for 5 mins it didn't seam a lot better although it didn't cut out straight away.
i then tried a couple more times then got scared i would break it!
i'm just hoping i haven't bought a duff car!!!
Stupid of me really!
Old Apr 20, 2006 | 09:34 AM
gotswap's Avatar
You should be OK. Get the new gas and enjoy
Old Apr 20, 2006 | 11:35 AM
Dopes6070's Avatar
new gas, change the oil then go have some fun.
Old Apr 20, 2006 | 12:23 PM
Bassy's Avatar
hey guys,
thanks for your help ive been really worried that i may have damaged the engine, i have it booked in for an oil change and fuel drain, hopefully then i can enjoy!!
by the way what do they go like?
i cant stop dreaming about driving it!!!!!!!!!
im crazy buying it without testing it but somehow i love the car and have known for 4 years i MUST HAVE ONE so i bought it
Old Apr 20, 2006 | 12:34 PM
islandmonkey's Avatar
speaking of fuel..... does everyone agree that premium fuel is the only option for our s2000,s
Old Apr 20, 2006 | 02:08 PM
gotswap's Avatar
Search is your friend.
https://www.s2ki.com/forums/index.php?showtopic=282177
nnnc3v
Apr 18, 2018 10:34 AM
ESCALVANTE
Apr 5, 2008 11:05 AM
bigpurp
Dec 17, 2003 03:35 PM
jcr9
Nov 7, 2002 02:47 PM
Roadkill
Aug 30, 2002 09:04 AM
