Fuel pump not working
Yes I swapped in a known good pgm relay to test and also can see 12v at the sos relay out as well as further down to the actual plug harness right before it goes into basket. So all appears good up to the basket itself.
to add on to what flanders said about checking voltage with load. The ground may not be strong enough for stable voltage?
the spade connector acts as a second ground when the basket is bolted to the body.
are you testing with at least one of the nuts tightened? or is the basket just resting in the tank?
sorry if im not helping. lol
I have not. Since i'm testing at the plug, but with this test suggestion that plug will not be accessible due to it being plugged into the basket, where would you like me to test the voltage from? Peirce the same wire above connector? Or bellow connector at the blue wire from the two wire pnp harness that plugs into the pump?
Then you work your way back and hopefully find the problem
So considering there isn't a whole lot of "back" left( since I get voltage at top plug on connector - and i'm going to venture to guess that I will not see voltage on the wire nearest to pump you are having me test, if so does that pinpoint anything for you other then this replacement basket now gone bad? I will check both ends of the pnp connector from top plug connector to pump. There is anything else back from there that isn't getting voltage.
Ok well this is interesting but a little confusing. I shoved the probe in to the back side of the connector off pump closest to the top plug end and now the pump is priming! So only thing I can think of is somehow the blue wire wasn't making a good connection inside the plug until jostled it around? Makes me nervous putting it all back together now and not having it fail again. I think I will take the plug connector out of the pump basket I have coming and swap them. After that and taking another close look at connectors, not sure what else can do there. So again appears to have just been a bad connection but ironically an oem one, and the broken float arm from previous basket that was lost was just a coincidental circumstance finding it in pump area portion of fuel tank after this failure.
Thanks you guys for the assistance. Always nice with the once in a blue moon when I have a problem I cant figure out, others come to help me
Nice. I was gonna say some of our connectors are only rated for a certain amount of plugs - unplugs, as the female sides tend to spread. Like you mentioned, I'd replace that intermediate harness in the basket, with a new one so you got fresh tight female sockets
god this sounds so wrong.
