Gas Indicator
Old May 21, 2004 | 08:55 PM
learnerspermit's Avatar
Default Gas Indicator
Anyone had trouble with theres jumping around on them? Not staying steady but for what ever reason 3 tanks worth of gas It jumped around on me so I had to keep calculating how much gas and it was starting to worry me. So right before I posted it has magicly stopped. Did the Fairy Mechanic fix it last nigt or what?
Old May 21, 2004 | 09:04 PM
xviper's Avatar
It is possible that there is an interuption in the fuel level signal wire. It could be in the wiring harness - might not be a good connection. Or, it could be the signal wire may be getting pinched somewhere. I have a feeling the situation will return.
Have you ever had any fuel pump work done on the car?
Old May 21, 2004 | 11:27 PM
MaxGeek's Avatar
I had the same problem I dunno if its as bad as yours but after driving about 30 mins mine said it had 2 bars left. Then when I started the car again like 3 hours later it said like 5 bars left. Drove all the back home and it said 3 bars left.
Old May 22, 2004 | 12:27 AM
hpark's Avatar
hmmm this happens in my analog gauge in my '97 maxima, but i've never had this occur in my MY04 S2000 ~3000 mi.....it goes down only (though not linearly) without jumping back up
Old May 22, 2004 | 08:13 AM
No I have never had any fuel pump work.
Old May 22, 2004 | 02:19 PM
xviper's Avatar
Another clarification:
When you say, "jumping around", do you mean it fluctuates up and down over a time frame of seconds or do you mean over a time frame of minutes. If it is minutes, this is normal and is usually confined to the bottom 1/4 of the tank. Seconds, it is not.
Old May 22, 2004 | 09:17 PM
No its changes randomly till a half tank is left then it reads correctly
Old May 23, 2004 | 05:38 AM
xviper's Avatar
This is not normal.
Emster
May 22, 2014 03:14 PM
bS2k_y
Aug 20, 2010 03:20 PM
RobbieS2000
Oct 2, 2006 03:50 AM
PatS2k
Jun 19, 2006 03:36 PM
dangarza
May 21, 2003 01:13 PM
