gears/differential
Old Mar 4, 2009 | 01:08 AM
kharaal13k's Avatar
Default gears/differential
i hear the s2000 has a weak differential. and i see a lot of posts talking about changing gears.
my question is. what would be good to build a solid differential and how much will that cost? as well as what kind of gears should i use?
thanks.
Old Mar 4, 2009 | 01:17 AM
kharaal13k's Avatar
also off topic, my clutch pedal is starting to stick at the very bottom and then spring back up..clutch fluid is fine and no leaks...i feel like i either need to bleed the slave cylinder or grease the metal ball at the head of the slave cylinder. any input?
Old Mar 4, 2009 | 06:59 AM
r6elmo's Avatar
go into th e FAQ, there is something there about the sticky clutch.
you can upgrade to the Ap2 diff and/or get the diff reinforced.
I personally don't worry about it, don't do bad launches or hard power shifts
Old Mar 4, 2009 | 03:34 PM
kharaal13k's Avatar
how do i get the diff reinforced and how much am i looking at spending
Old Mar 4, 2009 | 03:52 PM
S2KPUDDYDAD's Avatar
Lots of great info in this thread
https://www.s2ki.com/forums/index.php?showtopic=669453
Old Mar 4, 2009 | 06:28 PM
negcamber's Avatar
PM S2KPUDDYDAD...he's the reinforced diff master.
Old Mar 4, 2009 | 08:13 PM
newnan-s2k's Avatar
as far as your clutch goes, i had the same problem with the pedal....it was a my master clutch cylinder...it was just shot and needed to be replaced....i did the slave as well while i was on the task
Old Mar 8, 2009 | 10:40 PM
kharaal13k's Avatar
it was not that. it was the slave cylinder head being messed up from the fork. i read a diy thread here and it said to sand it down and i did and it works great now. thanks though!
S2K_1987
Sep 25, 2007 08:07 PM
A769
Feb 15, 2006 11:07 AM
ahbongkadah
22
Jan 24, 2006 06:27 PM
buzilanga
Aug 6, 2004 10:20 PM
