gears/differential
i hear the s2000 has a weak differential. and i see a lot of posts talking about changing gears.
my question is. what would be good to build a solid differential and how much will that cost? as well as what kind of gears should i use?
thanks.
thanks.
also off topic, my clutch pedal is starting to stick at the very bottom and then spring back up..clutch fluid is fine and no leaks...i feel like i either need to bleed the slave cylinder or grease the metal ball at the head of the slave cylinder. any input?
go into th e FAQ, there is something there about the sticky clutch.
you can upgrade to the Ap2 diff and/or get the diff reinforced.
I personally don't worry about it, don't do bad launches or hard power shifts
Originally Posted by kharaal13k,Mar 4 2009, 07:34 PM
how do i get the diff reinforced and how much am i looking at spending
https://www.s2ki.com/forums/index.php?showtopic=669453
ahbongkadah
22
Jan 24, 2006 06:27 PM
