gears poping out
I believe up until 2006 or 07 there was a recall on civics, s2000's and a some other Honda's that have had this problem, my buddy with his civic si was having that problem and it would happen off and on, and the only way Honda fixed it is if they could recreate the problem, so he had to drive around with a tech for quite a while, but they will fix it.
Theres a Technical Service Bulletin for this.
TSB 05-009
Applies to:
2004 S2000 - All
2005 S2000 - From VIN JHMAP2...5S000002 thru JHMPA2...5S005719
Symptom:
The transmission intermittently pops out of 2nd gear on high RPM decelration, or 1st gear while engaging the clutch
Probable Cause:
The manufacturing tolerances on 1st and 2nd gear synchros are at the limit of their specifications.
Corrective Action:
Replace the 2nd gear set
Parts Information:
2nd Gear Set: P/N 23432-PCY-336, H/C 8253841
TSB 05-009
Applies to:
2004 S2000 - All
Symptom:
Probable Cause:
Corrective Action:
Parts Information:
fisting dwarves
Jan 1, 2004 02:05 AM
