Getting engine off box
Old Jun 14, 2014 | 07:56 PM
Matts2k87's Avatar
Default Getting engine off box
So I've disconected every thing that I need to and split the motor from the box. I have nearly a half inch gap the whole way around. It's clearing the dowel pins, but I can't manage to get engine to come off the shaft in the box. I have the box jacked up a bit and started to hoist the motor on the same angle (tried a few different angles) with two guys trying to giggle it free, but we can't get any more than that half inch gap? Any help or ideas would be great!
Old Jun 14, 2014 | 08:06 PM
Mister Jew's Avatar
What?
I'm trying to understand. Are you removing the cylinder head from the block? Are you trying to pull the entire motor?
Old Jun 14, 2014 | 08:12 PM
Matts2k87's Avatar
Sorry mate, engine off the transmission. My tail shaft is siezed onto the diff so I can't get it loose to drop the gearbox underneath so I've been advised to jack the gearbox a little and slide engine off the shaft
Old Jun 15, 2014 | 03:06 AM
Pitcru's Avatar
Did you remove the clutch fork?
Mark
Old Jun 15, 2014 | 05:14 AM
Matts2k87's Avatar
No I haven't, I was unaware of that. How do I get the clutch fork removed?
Old Jun 15, 2014 | 09:02 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Unbolt slave.
Remove boot.
Pull out/disengage fork by hand. It will pull out about 2 inches or so, but not completely out.
Trans will surely come right out then.
Old Jun 15, 2014 | 05:12 PM
Matts2k87's Avatar
Thanks guys! Saved me 1 massive headache. Now to just get the thing back together
Funtimefrankie
Nov 13, 2012 07:51 PM
mr-pitts
Nov 25, 2011 12:06 AM
andyj1985
Jan 16, 2011 12:21 PM
Bibbs
Apr 21, 2008 08:45 AM
kstokell
Aug 29, 2004 01:42 PM
