Grease
Old Aug 13, 2006 | 08:32 AM
QUICK_AG's Avatar
Default Grease
Yesterday I installed my new differential and also installed the Motoklasse driveshaft spacers (my car is lowered with espilir springs). After going through the break-in period and raising the car back up on a lift to change fluid, I noticed grease (not rear-end fluid) under the rear area. I inspected the cv boots fairly closeley and was unable to find a tear or hole in any of the cv boots. Is it possible that by installing the Motoklasse spacers that I have compressed the halfshafts and they are spiining out excess grease? Please no flames. I am unsure as to where this is coming from. Any suggestions or help woukd be great. Thanks.
Old Aug 13, 2006 | 08:41 AM
xviper's Avatar
Check you diff mounts. They are liquid filled.
Old Aug 13, 2006 | 09:10 AM
SpitfireS's Avatar
xviper Posted on Aug 13 2006, 06:41 PM
That fluid is red, right?
Old Aug 13, 2006 | 09:32 AM
Ek9's Avatar
Ek9
Banned
If they're spinning out grease, you should be able to see a line of grease on the body where it's flung away from the CV's. At least my CV's did that before I replaced the boots. I was never clear if they leaked because the boots were loose or there was too much grease in the them. I still get some grease seepage around the edges of the boots. Not enough for me to worry about though.
What's the chance you cut a balljoint boot?
Old Aug 13, 2006 | 10:11 AM
xviper's Avatar
Yes, but by the time dirt and crud get on the grease, it can be brown to near black.
Old Aug 13, 2006 | 05:06 PM
QUICK_AG's Avatar
I'm pretty sure the stuff is grease, as it has a dirty bluish-green tinge. I was not aware that the diff. mounts were liqued filled. I will check those out also and there is a significant amount, enough to be worried about in my opinion. Also there is no odor to this stuff so I know its not diff. fluid.
Old Aug 13, 2006 | 06:42 PM
xviper's Avatar
If that's the case, it's likely CV boot grease.
Old Aug 14, 2006 | 02:04 AM
QUICK_AG's Avatar
I'm going to re-check the cv boots again and see if I can find a hole or cut. Thanks for the input.
onecleanS2000
Apr 9, 2017 04:54 PM
angryfist
Apr 30, 2013 10:16 PM
I spy Psi
Jan 20, 2010 07:12 AM
Swiftoy
Apr 27, 2006 11:20 AM
S2FiONE
Apr 21, 2006 08:54 AM
