Half shaft spacers.
Originally Posted by RED MX5,Jun 6 2007, 03:24 PM
Except that the spacers do not move the spider deeper into the cup, they move the cup further out over the spider, which is like putting the socket on an extension, an act which makes it weaker rather that stronger.
Just my theory anyway.
Here's a comparison of two Ford half shafts, one of which has had the weak link strengthened. Notice that the CV joints at both ends of the shaft are the same size, and appear to be OEM parts. That's because the joints aren't the weak link; The SHAFT is what normally fails first in high power applications using the Thunderbird half shafts.
Billman and others, is this not also the case with the S2000 half shafts? I know our half shafts are something like 50% stronger than is normal Honda practice for the cars stock power level, but isn't the shaft itself still going to twist and/or break before the CV joints?
The CV joints have to wear out before they fail, don't they?
Originally Posted by Billman250,Jun 7 2007, 04:32 PM
The first thing to break is the tripod on the s2k axles. It splits open and the axle spins inside it.
You can just replace the tripod and put it back in service.
Originally Posted by RED MX5,Jun 7 2007, 01:46 PM
but the lever arm doesn't really change. There's just more socket sticking out below the bolt. So relatively speaking, there is no change at all.
If you (or anyone else) has some evidance that Honda did not design our inner CV joints properly, so that they operate through the entire range of suspension movement without excessive vibration or stress, I'd like to see it (and I'll bet Honda would too). All the BS about changes made to the AP2 to "allow the car to be lowered" have been exposed as a tissue of lies, so why try to defend this stupid idea any longer. The spacers do NOTHING beneficial. If that's not so, let's see some proof.
My main point is still only that the back of the socket (or cup) is stronger than the open end, since it is supported by the metal of the base.
I am not trying to defame Honda's engineering or sell any spacers. My drivetrain is pure stock Honda, no complaints. I do enjoy my AF S/S though. Just some mental gymnastics, which we all indulge in here. If proof were so easy to come by, these forums would have far fewer posts.
