Hard to startup...
Old May 3, 2007 | 08:09 PM
Black_SIIK's Avatar
Default Hard to startup...
Hi all,
I took out the injector and have it clean. put the injector back and the car run very nice and well...
the only problem is that .. its harder to start the car, I have to press on the start button longer then normal...
Can someone help??
Thankz..
Old May 5, 2007 | 08:18 PM
Black_SIIK's Avatar
Anyone? no one?
Old May 6, 2007 | 07:23 AM
soulstealer1984's Avatar
did you have any problems befor you messed with the injectors? if not this one has me stumped...maybe fuel pump
Old May 6, 2007 | 09:02 PM
Black_SIIK's Avatar
Yeah..the car was running like shit, as it keep dying when i stop at the light, then i got the injector clean and the car now running as normal..
only startup is having a problem... the car start everytime, but the problem is that i have to hold the start button longer then normal..
Old May 7, 2007 | 09:01 PM
have you checked you fuel filter? if your injectors were clogged then maybe your filter is too. If the car is running fine other wise its prob not spark, compression, or air, so all that leaves is fuel. I had an older car that was carberated (i know not the same) and the fuel pump was bad and all the fuel would drain back into the tank. The resualt of this was everytime i went to start it the fuel had to come from the tank all the way to the engin befor it would start. Very long start up!!! Now if you are only talking about a couple of seconds to start it I dont think this would be the problem, but it could be. Ultimatly I would guess that the problem lies in the fuel system not with anything else. But that is just a guess. I just dont see how it would be any of you other basic componants.
Old May 7, 2007 | 10:45 PM
iam7head's Avatar
there's no real fuel filter in the S, as far as i know, honda stop using real filter around middle of 90's.
to the op, did you have the injector cleaned by professional? or you just dip those suckers in actone?
Old May 8, 2007 | 09:32 AM
i could be mistaken but i thought there was one back by the fuel pump. but i could be wrong i only have 30,000 on my car so i have not even looked into changing it. i was just trying to figure out what could possibly be the problem. As you know its hard to do a good diag on a car with out seeing it, so all of my ideas are just that ideas.
Old May 8, 2007 | 04:52 PM
silvers2k01's Avatar
There is no fuel filter, only a fuel sock in the tank.
Honda didnt stop putting fuel filters on cars in the 90's. my 01 gsr has one, to whoever posted that comment
Old May 8, 2007 | 10:14 PM
iam7head's Avatar
oh, of course, i am not saying anything bad about your advice.
it just that there's no real fuel filter in the S, there's a mesh/nylon sock around the pump and that's about it. it filters out big rock and quarters and that's about it
silvers2k01: let me make it clear: they stared to do that around mid 90's, i didn't say they stop putting fuel filter all at once and for all at 90. your gsr has one because it's a 8 year model runs?
ZSH_S2K
Feb 8, 2019 01:31 PM
CyS2k
Aug 22, 2014 11:21 AM
MandaJane
Jul 22, 2013 11:14 AM
DFWs2k
Jan 10, 2013 10:18 AM
jb34304
Nov 25, 2010 05:55 PM
