Head Gasket
Old Dec 16, 2011 | 09:46 AM
Mondo131's Avatar
Default Head Gasket
I have done a few searches as well as looking through the DIY and Guide threads and cannot find anything that has much information about Head Gaskets for our vehicles.
AP1 Motor.
I'm fairly competent when it comes to working on vehicles, but I try to research before doing any major job.
Should I purchase an exact OEM replacement, or are there other HG that offer certain advantages over OEM.
Any steps/areas I should use caution around when replacing the Head Gasket?
This will not be my first HG replacement.
Old Dec 17, 2011 | 06:42 AM
Mondo131's Avatar
Bump
Old Dec 17, 2011 | 01:39 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
What is the issue with yours now?
Old Dec 17, 2011 | 02:22 PM
Mondo131's Avatar
Coolant in middle 2 cylinders.
Old Dec 18, 2011 | 07:05 PM
Stratocaster's Avatar
Why is there coolant in 2-3?
Old Dec 19, 2011 | 01:39 PM
Mondo131's Avatar
My best guess is a blown head gasket, ie this thread
Old Dec 19, 2011 | 04:09 PM
SgtB's Avatar
If it's stock, stick with a OEM style gasket. I would check the decks for levelness and replace the head bolts if they've been off before. I believe you need to change them anyway as I believe you can only reuse them once being a torque to yield fastener. Is there any extreme cylinder to cylinder wear on the top lip?
Old Dec 21, 2011 | 12:12 AM
MP2k's Avatar
I notice you owned a 7M
I really have nothing much to add other than I've heard that Cometic is good about making any kind of gasket you want. I've wondered about getting a thinner one made to bump compression just a lil.
Old Dec 21, 2011 | 11:08 AM
speedjunky01's Avatar
OEM is the best gasket and its priced fair
grab a set of ARP studs as it will be cheaper to buy then once then head bolts a few times if you turn out to have a block or head flatness issue
PN 12251-PCX-004
51.29+ SH
http://www.hondapartsdeals.com/hpa_p...onGroupID=9085
studs are 113 these guys are usually the cheapest when it comes to ARP hardware Ive bought from them before and they are great to deal with
http://lightningmotorsports.com/arp/...2/i-61557.aspx
so for a total of about 175 plus a bit of coolant you should be all set!
LAE
Nov 25, 2018 04:45 PM
dan_bourne
Sep 18, 2012 10:06 AM
*JG*
Aug 10, 2012 12:16 PM
konerri
Mar 23, 2010 10:05 PM
RedLineS2k10
Mar 19, 2010 07:01 PM
