Head Stud Torque
Old Jul 19, 2008 | 10:04 AM
supahman04's Avatar
Thumbs up Head Stud Torque
So Im rebuilding my engine and Im ready to put the head back on. Simple enough. Problem:
I ordered ARP head studs. The instructions say to torque the studs to 80.
The manual says:
Tighten the cylinder head bolts in sequence to
29 N m (3.0 kgf.m, 22 lbf ft). Use a beam-type
torque wrench. When using a preset-type torque
wrench, be sure to tighten slowly and do not
overtighten. lf a bolt makes any noise while you are
torquing it, Ioosen the bolt and retighten it.
Turn the bolts 3 times (new) at 90 degrees per turn.
So which do i go with????
Old Jul 19, 2008 | 01:17 PM
Togobox's Avatar
go with arp instructions since it's not honda bolts, i think the ARP's are 2 steps if i remember.
Old Jul 19, 2008 | 09:51 PM
supahman04's Avatar
It just says torque to 80 if you use the ARP moly lube or 120 it you use motor oil.
Old Jul 20, 2008 | 06:54 AM
MitsukillinS2K's Avatar
Use the ARP instructions. They designed the bolt they know whats good
Old Aug 12, 2008 | 10:45 AM
lowandsmooth's Avatar
Use 80 mine is apart right now cuz i didnt enough said
EK9MAX
Jun 19, 2009 05:01 PM
CaymanS2k
May 20, 2007 04:47 PM
fperra
Sep 10, 2004 07:36 PM
Jason00S2000
Jun 29, 2004 08:46 PM
