header bracket bolt stuck!
Old May 15, 2008 | 08:46 PM
TelosHedge's Avatar
Default header bracket bolt stuck!
ok so i get down to yanking off my header tonight to start the greddy kit install...
i have all the header nuts off at the top and both spring bolts out of the cat. the only thing left to pull off is this bracket that attaches to the side of the block...
yea it wont come off. i have been cranking at this thing for an hour and it WILL NOT loosen up. at first i gave it a good crank with a breaker bar and things went smooth for about 3 turns after that... now it is stuck again and it just refuses to move. what is the deal? i did a little search and it seems nobody else has had a big problem with this. in fact most installs dont even mention this bracket at all!
someone chime in and help. thanks much
Old May 15, 2008 | 09:47 PM
Olegator's Avatar
your problem might be that you decided to loosen it last, by doing that you have put all the weight (or part of it) of the header on that bolt, so while turning it the bolt might have misaligned....
Old May 16, 2008 | 01:03 PM
TelosHedge's Avatar
well god knows what i did (i think olegator was right) but i went to town on this bolt for another 20 mins and broke it in half. works for me!
Old May 16, 2008 | 01:07 PM
marks_lude's Avatar
I wouldnt ever use a breaker bar on an aluminum block. chances are part of the bolt was seized, and the breaker bar was strong enough to shear the aluminum threads off the block and they are stuck to the bolt. If this happens at the deep part of the bolt, then you have aluminum gunk in the threads thats trying to back out through the threads that mate with the part of bolt closer to the head.
If this is teh case, you should be able to tight the bolt back up pretty easy (or alteast easier)... but it still wont want to come back out past a point.
I accidently put a wrong starter bolt into my prelude that was too long and it threaded in to deep into the part of the hole thats not threaded, grabbed some some block material that stuck in the threads of the bolt and it was a bitch to get out. I basically forced it out, and re-tapped the threads afterwards. the tip of the bolt had the threads filled with aluminum.
anyways, good luck, hope thats not the case for you!
Old May 16, 2008 | 03:19 PM
TelosHedge's Avatar
luckily i was not fighting with a bolt that was stuck in the block - it was on another piece of the bracket that was on the block. i did not hurt the block at all (nor would i ever try to risk it!)
in my case it worked out. the bolt sheared in half and let the header fall off the bracket. no problems
aside from that on a side note my install has been seamless so far! in 3 hours we managed to put on the manifold, turbo, downpipe, all gauges and sensors, oil relocation, intercooler, and some piping. i had to stop and goto work though
hopefully tomorrow brings more good news and less broken bolts!
Old May 16, 2008 | 03:30 PM
1320performancefreak's Avatar
happy to hear it would out for you. hows the weather in NY? over here in CA its like 102 today i am not even gonna try to work on the car
Old May 16, 2008 | 04:00 PM
TelosHedge's Avatar
it was rainy all day and i was off - GREAT DAY to stay in the garage and get it all done!
svencarlson07
Oct 28, 2010 11:51 AM
rickw06
Jan 10, 2009 03:44 PM
Freakaccident
Aug 26, 2002 11:35 PM
johev
Sep 13, 2001 10:17 AM
revhard
Aug 17, 2001 09:04 PM
