Sponsored by: CARiD
fitting a new header?
Old Jan 10, 2009 | 04:45 AM
rickw06's Avatar
Default fitting a new header?
hey ill be picking up a j's header shortly and was wondering is it hard to install?
bcaus was just gonna try fit it myself? wont have a ca lift or anyting just will have the car jacked up?
thanks for any help rick
Old Jan 10, 2009 | 05:02 AM
04ssonbl's Avatar
When I did my buddys header I had it on a lift and it was still crappy. Even with all the right tools!!
Old Jan 10, 2009 | 05:13 AM
jkuamoo's Avatar
i highly recommend installing the header on a lift.
after searching through previous owners experiences i found out that it is in fact easier to install the header by removing the motor mount.
the motor mount is really easy to remove 4 bolts hold the motormount bracket to the block and one bolt holds the bracket to the crossmember.
when i put in my berk header i completely removed the header including the bracket and base plate (motor mount bushing). removing it is pretty straightforward- make sure you re-torque the bolts to spec upon re assembling everything, the header has plenty of space if you do so. oh and you have to remove the heatshield first as it gets in the way when your trying to remove the header nuts where it mounts to the head.
pm me if you have anymore questions.
Old Jan 10, 2009 | 05:35 AM
rickw06's Avatar
thanks for the reply mate
tink i miht just get someone to fit it for me.
Old Jan 10, 2009 | 05:44 AM
S2K 4 ME's Avatar
If you put it up pretty high on jack stands it shouldnt be a problem. I put my Berk header on while it was on stands and didnt have much trouble as long as o have room to maneuver the header around from underneath.
Obviously a lift would make it really easy, but just know its not a big deal if you go the jackstand route either.
Old Jan 10, 2009 | 01:37 PM
a_zepeda926's Avatar
i didnt install mine myself, but brian @ berk (who installed mine) told me if i ever had to remove mine for some reason to just jack the car up really high. you just have to work the angle's to get it up in there.
Old Jan 10, 2009 | 03:44 PM
g352s2k's Avatar
yep just jack it up all the way.....best tool for me was a breaker bar.....the oem header wiggles right out and the new one should wiggle right in.
jon o
15
Oct 16, 2012 05:36 PM
skibum
Jul 2, 2009 06:23 AM
Madhatchz
Aug 25, 2007 03:33 PM
HNC
Aug 12, 2007 01:05 AM
gary_phd
Dec 29, 2005 07:13 PM
