Hell of an engine noise
Old Jul 15, 2008 | 06:48 PM
Togobox's Avatar
I think the engine ran low on oil, rod knock to me.
Old Jul 15, 2008 | 08:30 PM
VashRacing's Avatar
Thanks for all the responses, I only ran the engine to take the video.
Sounds like it would be best to pull the motor. Hopefully I can get on that soon, I will do my best to keep you updated.
Just out of curiosity, assuming it is a scuffed bore. What would cause that?
Old Jul 15, 2008 | 10:33 PM
21337R's Avatar
Am I wrong or did the OP's vid sound way faster than the confirmed scuffed bore vid. I realize that the OP's was cold and Idling a little high but still... sure sounds like the head to me.
Old Jul 16, 2008 | 09:36 PM
VashRacing's Avatar
Well i think the next step will be to do a leak down test and use a bore scope to try and figure out what wrong before a full tear down.
Old Aug 13, 2008 | 06:45 PM
VashRacing's Avatar
Ok I finally figured out what was wrong with my car. Like Billman250 said it was in fact cylinder #4 with a scuffed bore. I finally got my hands on a bore scope that worked and it didnt take long to figure out what was wrong.
Once we move I will start working on my car that and I need to save up for the repair. Mostly for Billman250 and Soul Coughing, what could or is the probably reason for that kind of damage?
Old Aug 14, 2008 | 05:59 AM
mxt_77's Avatar
You have an MY00... do you have the upgraded oil jet bolts?
Old Aug 14, 2008 | 08:17 AM
VashRacing's Avatar
I personally have not done anything with that, I can check to see if the previous owner did. Was it a recall item or some type or TSB?
Old Aug 14, 2008 | 08:20 AM
mxt_77's Avatar
Not sure. Maybe some info in this thread?
https://www.s2ki.com/forums/index.php?showt...ht=oil%2520bolt
Old Aug 15, 2008 | 10:52 AM
VashRacing's Avatar
I looked into it there are only 2 recalls on my car and they were both performed and there are also no TSB's that deal with that engine problem at all.
Thanks for the link I hadnt really heard about that bonjo bolt thing before.
Old Aug 15, 2008 | 01:41 PM
s2k aok's Avatar
my celica gts has a similar noise (valve tap) but on the 2zz it's considered normal...
AbsoluteFreedom
Oct 4, 2016 05:09 AM
Peeves
Oct 17, 2015 08:46 AM
Nexridge
Aug 2, 2015 12:34 AM
Xene
May 1, 2012 01:41 PM
BlueSTwoK
Feb 24, 2005 04:16 PM
