Help! Car wont go into fifth gear
After regreasing my shifter and putting everything back together, my car will not go into fifth gear. It goes into every other gear just fine, including reverse. Im pretty sure theres only one way to put it back in, i even tried taking it out and putting it back with no success.
In neutral the shifter goes too far to the right and barely to the left. I think the shifter may be bent. I can get into fifth if i go directly from fourth. If i try to go from neutral to fifth it wont go in.
Yes, it was working fine before. I pretty much took it out to replace the two plastic pieces on the shifter. However, when my dad was helping me taking out the bigger plastic piece, he had one end on the floor while hitting it with a flathead. That is what makes me think something may have bent. It may be me, but after putting the shift knob on, it doesnt sit perfectly straight. Neutral also feels weird, it is able to move all the way to the right, and only a little to the left. Other then that, it shifts fine.
You are certain that you overcame the spring tension, and torqued the three 10mm bolts evenly? I cannot think of any other reason for the symptoms you describe. And you're right, it only goes in one way.
Edit: Something weird i just noticed; I can put the car in reverse without pushing down.
UPDATE: I think I found the problem after some more searching..
http://s2000.com/forums/engine-tech-...-has-been.html
Gotta order that stupid piece again and wait a week for it to ship -_-
dievoche
Dec 16, 2010 11:56 AM
Squeezer
Apr 26, 2004 10:19 AM
